Old 07-12-2009, 09:39 PM   #1
gcburdic
Restoration Virgin!
gcburdic's Avatar
Valve cover gaskets and hold downs
So I finished polishing these up and want to know which VC gaskets and hold downs I should use....they are aluminum VC....(I have spreader bars and long T-bars, but wasn't sure if I should reuse those??)
Thanks for your input!!!...Geoff
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-12-2009, 09:55 PM   #2
crm318
Alright Alright Alright
crm318's Avatar
Re: Valve cover gaskets and hold downs
I dont think youll need to use spreaders. Those valve covers are thick casted and the are designed better.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 07-12-2009, 10:45 PM   #3
1967C20
Junior Member
1967C20's Avatar
Yeah, what he said. Also, you can use regular gaskets. Just don't tighten too tight; could crack the valve cover. Cast covers seal so much nicer than the stamped stuff.
"A man's got to know his limitations." - Dirty Harry
_______________________________________________
1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker
1967C20 is offline   Reply With Quote
Old 07-12-2009, 11:53 PM   #4
tim21391
tim21391's Avatar
i use high dollar ones that have copper in it.. they are blue rubber with the copper or whatever in them its about 40 bucks for them they are reusable
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 07-13-2009, 09:33 PM   #5
gcburdic
Restoration Virgin!
gcburdic's Avatar
Thanks for the input...I picked up some Fel Pro Perma Dry Plus (part #VC12869T)...
these things are stout!!...Silicone around a steel core....Paid $32 for them at NAPA....
Geoff with a G
Old 07-13-2009, 09:46 PM   #6
leddzepp
Moderator
leddzepp's Avatar
gcburdic- You bought the correct gaskets. You will not be disappointed with those.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-13-2009, 11:01 PM   #7
bamabaxter
bamabaxter's Avatar
Just lettin ya'll know Napa carries a cork gasket that is twice as thick as the normal ones they stock for a SBC. You have to ask for them and they are only about 12 bucks. I know there are others out there like me that just will never use anything but cork. just a little extra info that is all. I know which gaskets you bought and they are definitely some quality gaskets. Don't want anyone to think I was knockin' them.
'72 Chevy C10
383, 700r4, 3.73's
A little rust never hurt anyone. I consider it weight reduction.
bamabaxter is offline   Reply With Quote
Old 07-14-2009, 01:06 AM   #8
tim21391
tim21391's Avatar
the perma dry was what i was talkin about.. i got them on my dads mustang.. best ones i ever uses.. didnt even need adhesive
Old 07-14-2009, 07:48 AM   #9
KEL
72 GMC
KEL's Avatar
those look like the covers on my truck.
the flange was just enough thicker that my
stock bolts would not reach. might want to
check that before you start with the rtv.
KEL is offline   Reply With Quote
Old 07-14-2009, 08:06 AM   #10
Ole Blue 68
Ole Blue 68's Avatar
Agree on the Perma Dry. Put them on mine and no more leaks.
Ole Blue 68 is offline   Reply With Quote
Old 07-14-2009, 09:08 AM   #11
Sinister
Between Trucks...
Sinister's Avatar
Nice valve covers. I think Summit has aluminum t-bars, chrome ones might look a little off next to the aluminum. Studs and nuts would look good too.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-14-2009, 11:36 AM   #12
gcburdic
Restoration Virgin!
gcburdic's Avatar
rtv is not needed on these gaskets, but I appreciate the heads up for the fit issue.....
Thansk Sinister....I'll check it out!!!
Geoff with a G
Old 07-14-2009, 11:56 AM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I always figured those t bolt quick release fasteners kind of implied that I was always having to work on my engine.
BTW, Permadry gaskets are the best. I've used the same set on several engines.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-14-2009, 12:54 PM   #14
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
I used Mickey Thompson cast aluminum covers on my SBC and the extra thick gaskets from Napa. I bought a tube of Permatex no.2 soft gasket gunk and applied it to both sides and installed them. My covers didn't even come with spreaders as I think only pressed steel covers use them. One thing though, After I tightened the wing style bolts down the next day I found them fairly loose. I retightened them repeatedly for the next few days and now they are nice and tight and no leaks!
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 07-15-2009, 09:09 PM   #15
gcburdic
Restoration Virgin!
gcburdic's Avatar
So I installed the VC and gasket, but passenger outside between the t-bars it leaks some.....any idea what I need to do to make it seat better.....I didn't think I should use gasket gunk???...It even says not to on the box???...Thanks
Geoff with a G
Old 07-16-2009, 11:10 AM   #16
Ole Blue 68
Did you use the spreader bars?
I had a leak on my driver's side and decided to use some RTV and that did the trick. I suspect that I may not be able to re-use that gasket though...
Old 07-16-2009, 01:02 PM   #17
gcburdic
Restoration Virgin!
gcburdic's Avatar
Nope...didn't use the spreaders....I'll check to see if the t-bars are bottoming out and not seating on the gasket tonight.....may go w/ the rtv if all else fails!!!
Geoff with a G
Old 07-16-2009, 01:10 PM   #18
Tx Firefighter
There is something wrong then. Felpro designed those gaskets to be installed without sealer. I have a pair of them on different engines and even different valve covers and never a leak without sealer. When I blew up the engine, I took the ARP bolts and the permadry gaskets off of it before I scrapped it and used them again on the next engine. I put 100k miles on the next engine.
Either your valve covers are warped, there is some foreign matter on the head where the gasket seats, or the bolts are bottoming out in the holes before the cover is cinched down.
Old 07-16-2009, 01:19 PM   #19
gcburdic
Restoration Virgin!
gcburdic's Avatar
Thanks TX FF....I did have the VC on a flat surface to make sure they weren't warped when I bought them....I did check/ wipe the lip of the head before installing the gasket....so the last thing I need to do is check for the bolts bottoming out (I hope this is the case)....can you recommend better hold downs (I definitely don't like the t-bars)...you mention ARP...where can I get some??
Geoff with a G
Old 07-16-2009, 01:25 PM   #20
Tx Firefighter
I get all my parts from Summit.
Old 07-16-2009, 01:42 PM   #21
Ole Blue 68
In my case it was the VC (cheap Edelbrocks) and not the gasket itself.
Old 07-16-2009, 06:07 PM   #22
gcburdic
Restoration Virgin!
gcburdic's Avatar
ah ha....these will work...thanks TX FF....http://www.summitracing.com/parts/ARP-400-7507/
Geoff with a G
Old 11-15-2009, 02:52 PM   #23
Hawker7
Did you ever get your valve cover to stop leaking? I have the same gaskets and mine is leaking on the back on both sides. I have taken them back off to make sure everything is level and torqued them to 3 foot pounds and still have leaks.
Hawker7 is offline   Reply With Quote
Old 11-15-2009, 05:08 PM   #24
bamabaxter
bamabaxter's Avatar
What kind of gaskets did you use? If you used cork, did you RTV them to the valve cover?
'72 Chevy C10
383, 700r4, 3.73's
Old 11-15-2009, 05:19 PM   #25
Hawker7
I used Fel Pro Perma Dry Plus rubber ones
