07-13-2009, 01:08 AM | #1 |
Home built Antiroll bar..
Ok, I'm either cheap or like to do stuff myself. Instead of buying a antiroll bar, I decided to build one.
I bought the rod ends and 1 3/4 bushings for an RV some time ago. Tonight got a chance to actually start building it. I had some 1 3/4 tube laying around as well as some 1/4 plate that I'll make the leverage arms out of. I also happen to find some tube to tie in to my rod ends. Just need to go buy 4 nuts to weld to the tube stock so I can adjust the angle of the antiroll bar. I'll try and get some picks next time I'm goofing around with it.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 07-13-2009 at 01:09 AM. |
07-13-2009, 09:21 AM | #2 |
Registered Truck Offender
Re: Home built Antiroll bar..
We want PICTURES!!!!!!
My Nova has a suspension issue and I tear up the cheep Jeggie anti-roll bars one a season. Short of the MW splined ends I've been trying to come up with something stronger. Soooo show us what the heck your doing there super!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 07-13-2009 at 09:22 AM. |
07-13-2009, 03:22 PM | #3 |
WE WANT PICS! you know better than to tease us.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
07-18-2009, 10:43 PM | #4 |
Sunburst C10!!!
whats the purpose in an antirollbar on the strip
Gage 1967 C10 Shortbed Stepside |
07-18-2009, 11:14 PM | #5 |
it helps to keep the car/truck from twisting up when it leaves the starting line.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
07-18-2009, 11:15 PM | #6 |
keep the truck flat... even the load between the tires
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
07-18-2009, 11:17 PM | #7 |
Sunburst C10!!!
thanks for the info
so whats the difference between the one super73 is building and the single bar that mounts to the axle i know what hes building ive seen them before i just didnt know what it was for
07-18-2009, 11:30 PM | #8 |
The factory one will twist a lot sooner, allowing for more rear axle wrap. The bigger thicker set up keeps the axle and chassis more level.
I found this very interesting.. http://stockcarproducts.com/tech1m.htm
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 07-18-2009 at 11:31 PM. |
07-18-2009, 11:33 PM | #9 |
Sunburst C10!!!
is this what your building
http://www.jegs.com/i/Jegster/550/40096/10002/-1
07-18-2009, 11:34 PM | #10 |
yup.. if you make it stiff enough you'll be able to sick a jack under one wheel and both will go up the same...
07-19-2009, 12:05 AM | #11 | |
Yes and no.. The mounts I am using are very similar to factory mounts but in 1 3/4" They even mount in the factory location (with a little massaging of the factory holes). 1 3/4" tube then goen in it and I am making the leverage arms from 1/4 plate steel, cutting them out with my plasma cutter then cleaning them up with a grinder. For now I'm going to weld the leverge arms to the 1 3/4" tubing. I'm thinking about having a set cut out with a water jet along with the 1 3/4 hole to slide the tube through then weld it up on both ends (inside and out).
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
10-10-2009, 08:18 PM | #12 |
Rusty but Trusty
How did this work? Did you make it to the track with it?
Pics would be nice also.
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built |
10-11-2009, 12:19 AM | #13 |
I'll see if I can snap some pics tomorrow.. I can't get to the track right now due to finances (I'm out of work). Need to make house payments instead.
