Old 08-04-2009, 10:35 PM   #526
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Daverods project 66
http://motors.shop.ebay.com/__?_from...ushrod&_sacat=
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 08-04-2009, 10:44 PM   #527
daverod
SSN 706
daverod's Avatar
Hay look what I found. What an idiot. I wasn't even sticking it in the right hole. Thats happened a few times the wife hates it. Thanks again. Ready to put my heads on tomorrow.
daverod is offline   Reply With Quote
Old 08-04-2009, 11:53 PM   #528
Strodder
Daring to be Different
Strodder's Avatar
Good call Gage
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 08-05-2009, 11:09 PM   #529
daverod
SSN 706
daverod's Avatar
Worked on my temp sending unit tonight. After much searching I found one that used two wires. You have to ask for a 64 gmc temp sending unit. Anyway swaped it out put in some more fluid and both lights still come on. If I drive fast the green one goes out and then the red fades to pink. Just sitting still they both come on. I thought it might be a bad thermostat so I changed that out. It had a 180 in it the guy at the store said 195 was stock so thats what I put back in it. More fluid and same thing. $30 and I'm right back were I started. I'm done messing with it. I'm sure I'm not overheating. When I get the time I'm swapping to the 66 dash and putting a tech in the dash.
Old 08-06-2009, 05:57 PM   #530
daverod
SSN 706
daverod's Avatar
Now all of a sudden my temp lights work the way they should. Worked good all day. Set my timing to 4 degrees hit the hiway and it started cutting out at about 45- 50. Went home changed it back to 0. Thats when I got confussed again. When I set the timing a pulled the hose off from the carb. to the dist. and pluged it. When I was messing around I noticed that when I rev. the engine up the timing changed even with the hose plugged. Is that the way normally works? I thought it got a vac from the hose and that changed your timing?
Old 08-06-2009, 08:27 PM   #531
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
check to make sure that your dist is tight, I could have moved when you rev it.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 08-06-2009, 08:34 PM   #532
Strodder
Strodder's Avatar
The distributor has a centrifugal mechanical advance that will work without the vacuum hose on. That's normal. With the hose on you can check total advance. If I remember right it should be about 32 degrees. To check total advance you have to have a timing light with an advance dial on it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-06-2009, 08:41 PM   #533
ruffrida2005
yeah good point Strodder, I was going to say the same thing. Man I got a lot more to learn.
Paul
Old 08-06-2009, 08:57 PM   #534
Strodder
Strodder's Avatar
So do I my friend. You never stop learning
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-06-2009, 09:10 PM   #535
ol Curt
Junior Member
ol Curt's Avatar
I'm 52...hoping to START learning at about 55 and start teaching at about 65.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 08-06-2009, 09:13 PM   #536
Strodder
Strodder's Avatar
I'm still not ready to teach.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-06-2009, 10:32 PM   #537
daverod
SSN 706
daverod's Avatar
Thanks guys. I was worried that it was'nt working but after messing with it I could see it move. I think I just set my timing to high. In a 73-86 ? book I saw that the timing was 4 degrees for a 292 thought I would try it. Back to 0 runs great. Still messing with my air screw though. When I screw it in it kills the engine but when I screw it out it doesn't seem to make a difference how far it won't make the engine studder. I just srewed it in untill I could tell a difference then backed it out a 1/4 turn. Tried hooking my vac gage to the hose going to the dist. but it would read anything untill I reved the engine up. Wish my notch would get here.
Old 08-07-2009, 07:44 AM   #538
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
You may be hooking it the the port that doesen't pull vacuum until the throttle blades are open. Most carbs have one that pulls vacuum at idle and the other that only has vacuum when you come off idle. From what I remember most chevy's use the off idle vacuum to the dist. But I have seen one or two that like it the other way!
You can usuallly tell which port will have constant vacuum and which want by looking to see which is above the throttle blades and which is below. The ones below will have vacuum at all times.
ChuckDriver is offline   Reply With Quote
Old 08-07-2009, 08:49 AM   #539
daverod
SSN 706
daverod's Avatar
It's below. It's the line that goes to the distrubitor vac advance. It on a 292 engine with a 2 barral thats all it has for lines.It also has one that goes to the pcv valve but thats a bigger hose and that's almost on the intake. I'm not even sure if that's where it normally go'es because when I bought the truck that hose was burned in half?
Old 08-08-2009, 04:06 AM   #540
watahyahknow
watahyahknow's Avatar
this was fun to read you guys crack me up .
back on rust preventing : an old mecanic i knew used old motoroil in hollow spaces he drilled a small hole in the top poured the oil in let it sit a while and drilled a new hole in the bottom draining it ,
gets in all the nooks and crannies and with the hotter weather and dust it prolly dries up intoo sumtin like tar ....... wouldnt want to weld on any of his cars though
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 08-08-2009, 09:06 AM   #541
daverod
SSN 706
daverod's Avatar
Thanks Watahyaknow. I'm always amazed by where people on this site are from.
Old 08-08-2009, 09:39 AM   #542
watahyahknow
the internet doesnt have boundries (whell allmost) when it comes to american cars and pickup trucks theres hardly a better place to go then to american forum's
Old 08-09-2009, 12:49 PM   #543
daverod
SSN 706
daverod's Avatar
Took the tail gate from my 66 and fixed it up go enough to work on my 64. It was'nt good enough for the 66. I'm going to buy a new one for that truck. But for my driver it will work good. I should have taking some pics when I was working on it. I pulled out what I could but it had a couple spots that looked like someone hit them with a golf ball. I cut those spots out hammered them flat and welded them back in. I think it turned out good. I did'nt want it to look new. I went real light on the paint and hit it with a little rust color after. I might color sand it until some of the primer start to show. Tightened up the chain fittings now it makes no noise. I might see if I can fix the old tail gate it was wacked. It might be good practice.
Old 08-09-2009, 12:59 PM   #544
Strodder
Strodder's Avatar
Looks like a waist of time. I would do something more productive.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-09-2009, 01:11 PM   #545
watahyahknow
think the best way to even try is to cut the bend sheetmetal off the carcas and try to bent new sheetmetal on the remains
Old 08-09-2009, 01:29 PM   #546
daverod
SSN 706
daverod's Avatar
Waste of time!! Your right. Cant spel werth $hit but your wright. It's not as if I don't have other stuff to do. I just like welding stuff.
Old 08-09-2009, 06:37 PM   #547
Strodder
Strodder's Avatar
That's what I meant. You have lots of other stuff you can be doing. If your bored you can come over here and help me. You now know where I live.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-09-2009, 08:07 PM   #548
daverod
SSN 706
daverod's Avatar
Better watch what you wish for. A guy said somtghing like that a couple years a ago I ended up in hawaii for 3 months built him a nice house. Lived in a little barn while we built it. Frogs everywhere. He never goes there. I use it more then him. When I get bored chit happens. Now if could just build a truck.
Old 08-09-2009, 08:12 PM   #549
Strodder
Strodder's Avatar
Screw the trucks, lets go to Hawaii.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 08-09-2009, 08:17 PM   #550
daverod
SSN 706
daverod's Avatar
Been there quite a bit. Next time I'm taking my bow and stickin a pig. Last time I went I took the old lady and we sheetrocked for a month. We would work about 4 hours then hit the beach.
