James
I can't find this mounting bracket anywhere.
I'm running a 292 originally out of a 66 3/4 ton. It has the original 1brl carb. My problem is that I lost my breather mount bracket and I can't seem to find one anywhere. No one seems to even have a carb like the one I have. So do any of you know where I might be able to get this bracket????
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end. http://viewmorepics.myspace.com/inde...lbumId=1709080 http://s258.photobucket.com/albums/h...e_top_view_all |
![]() Join Date: Sep 2006
Re: I can't find this mounting bracket anywhere.
probably just as easy to fab one up, tap the holes, use all thread to the correct height, fab a bar with holes to span it, then drill a center hole, tap or nut each side and another piece of all thread to fit your air cleaner nut,
but look inside your air cleaner, you may have just taken it off and its still attached. |
