Torque specs
So installed my new spindles last night and for the life of me I could not find the torque specs for the lower ball joint or the brake rotor spindle.
It's kinda wierd cause the book I was looking at had the upper ball joint nut torque spec....you'd think the lower ball joint nut spec would be right there....nope. BTW: 72 1/2 ton front suspension specs. |
![]() Join Date: Apr 2008
Re: Torque specs
German torque-goodundtight
Never Ending Projects
Re: Torque specs
These are the ones I saved from someone when I was looking.
C10 , C20/30 Upper ball joint 70 / 120 Lower ball joint 120 / 215 Tie rod ball joint nut 30 / 50 Tie rod clamp 132 in# / 132 in# Idler arm mounting bolts 30 / 30 Idler arm to relay rod 60 / 60 Pitman Arm 60 / 60 Pitman arm to selector shaft 125 / 125 All values are in foot pounds unless noted.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
