![]() Join Date: May 2002
FS: Chevy 355 and TH400 Transmission
I have a chevy 355, may need to be gone through, and a th400 for sale. these are at my parents house in Houston, and need to be picked up from there. I don't know what is wrong with the 355 (3970010 block with a .030 overbore using a stock 350 crank). I'm asking $250 for it (firm). It has an Edelbrock Performer intake (2101 I think), a brand new starter, a newly rebuilt distributer, and a new water pump. It also has an xtreme energy cam, a set of 882 heads, and some Hypereutectic pistons. I will not split anything on the engine.
I also have a stock th400 for sale. i'm asking $150 firm on it. it has about 20k miles on it, the torque converter, the electric kick down components, and the front section of a driveshaft with the proper yoke. I will not split the transmission stuff up either. Post in the thread if you want either
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 12-24-2009 at 11:01 PM. |
Re: FS: Chevy 355 and TH400 Transmission
Ok, took the valve covers off and checked the pushrods. there was one that was loose because of a bad nut. will replace the nut, but the engine will have to be retuned.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
ttt
ttt
ttt
ttt
![]() Join Date: Jul 2009
So did the engine run before taking it out. Is the only problem the loose rocker.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
Yes, it did run prior to being removed. Yes, the only problem is the loose rocker.
Could I have my engine guy come with me to check it out
sure, when did you want to come by?
ttt
ttt
ttt
ttt
#15 |
ttt
#16 |
ttt
#17 |
ttt
#18 |
ttt
| Bookmarks |
| Tags |
| chevy 350, engine, th400 |
