Old 12-27-2009, 01:16 PM   #1
lytemup454
lytemup454's Avatar
metal fuel lineto the carb?
hey guys,
I want to make a metal fuel line from the fuel pump up to the carb. I had two questions.
1.What fittings will i use to attach to the 90* elbow coming out of the fuel pump.
2. Will an standard 45* double flair work for this application?
thanks, just trying to do small little winter jobs to stay busy.
ian
lytemup454 is offline   Reply With Quote
Old 12-27-2009, 01:50 PM   #2
rick0312
rick0312's Avatar
Re: metal fuel lineto the carb?
had the same issue not to long ago I used 3/8" brake fitting and steel line. I ran it as far as I could up the block to the fuel filter. check out the old thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=352724
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 12-27-2009, 01:52 PM   #3
cdowns
cdowns's Avatar
rubber fuel lines like that are great until the fire
Old 12-27-2009, 02:32 PM   #4
lytemup454
lytemup454's Avatar
thats exactly what i was looking for thanks guys
Old 12-27-2009, 02:34 PM   #5
mr48chev
mr48chev's Avatar
The 3/8 male flair fitting on the line should screw right into the pump but you will need a good tube bender to make the 90 degree bend.
It's probably best to use a piece of welding rod or coat hanger to make your pattern with to get the right bends if you don't have the old tubing.
