67 Head Question
In this picture, what is this little plug on the head that the arrow is pointing to? I just got me a 67 head to go on my 81 and I don't know what it's for...I got the plug that came off of it but don't know what it goes to lol...any help?
![]() Last edited by hobsiscool; 01-13-2010 at 10:07 PM. |
Re: 67 Head Question
Anyone?
it should be the electric water temp sender to a electric temp gauge
Trueman |
Got ya...I was wondering why some folks had it hooked up and some didn't...guess I could replace that plug with a different probe...mechanical temp gauge perhaps?
**edit...guess I could just get another electrical water gauge huh...I see Autometer has a whole range of gauges... Last edited by hobsiscool; 01-13-2010 at 10:41 PM. |
the hole should be 1/2 in.-14 Thd or 3/8 in.-18 Thd. most parts stores have the brass thread adaptors or there in the manual temp gauge packages.
Trueman |
Junior Member
I don't believe that's for your temp gauge. It is a temp sender for the trans control spark system. It was an early emission control setup that affected spark advance. I'm no expert on it but I think it would kill vac advance unless the engine was in high gear or on cold starts (hence this sender)
70 C/10 LWB 250 ![]() |
So would I need to use it for a 3 speed manual from an 81? I've seen it hooked up and not hooked up on different setups.
Junior Member
I'd just leave it plugged with the sending unit in the picture, or if it is missing find a plug to use. No need to use it on your 81 unless you want another gauge. There should be a gauge temp sender on the water neck under the thermostat.
#9 | |
Trueman |
