#226 |
![]() Join Date: Apr 2005
Re: 68 S/C update.....
Thanks Heath.
I'll eventually get the brake pedal that matches or just take the chrome off of the gas pedal. They all are slanted /. 1-2 hrs depending on how you do it.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-11-2010 at 11:43 AM. |
#227 |
I like the fact that it was a nice truck to start with but it's so much more w/the simple details items & corrections made where necessary (5-crimps on one wire??; those rear coils??; the cheesy looking fuel cell & batt placement).
Excellent work on this one!
#228 | |
I finished the pedal upgrade. I used a extra Lokar cable I had laying aroujnd instead of using the 71/72 factory one. It worked a little better with the supercharger setup.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#229 |
some ricer guy will be PO'd that you got the last fancy blue anodized blow off valve!!!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#230 |
GEARHEAD
I think I want a lokar cable like that. You have a part #?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#231 | |
![]() This one should work, http://www.summitracing.com/parts/LOK-TC-1000U/. R/
#232 |
GEARHEAD
Thanks for the length. One question though, is the stated cable length from end to end of the cable or the sleeve?
#233 |
I'm not sure hgs. You might want to give Lokar a call. I know they offer a 36" one also.
#234 |
Rob, I think that you ahve done such an great job on this truck so far, , it to me is what hot rodding is aboutm, getting dirty and doing what you have to do to make her run!!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#235 |
+1 on the lokar products..Rob I used one in my truck when I built mine as well as the shifter rod, oil dip stick and tranny dip stick..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#236 |
Restoration Virgin!
gas pedal/ cable looks good Rob....I gotta get mine installed on the Mistress...maybe Toyota should take some notes
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#237 | |||
![]() OK, well my small pedal project project has turned into an engine compartment "remodel". I've wanted to move some stuff around for a while, I guess now is as good of time as any....
#238 |
Under Construction
looking good...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#239 |
Now what??
Looks good!
69 Long Fleet - Project 06 Ram 1ton Cummins 4x4-DD 01 Tahoe- wifes "The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi "A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell my, um, build ![]() ![]() ![]() |
#240 |
Thanks! I've finally got everything back together, but I'm still playing with my pedal setup. I also ordered an all new fuel setup that should be able to handle the demand of the S/C. I should have that installed by next week. Also, I had these wheels "laying around" and thought I would bolt them on to see how they look. What da ya think????
#241 |
67-72 parts collector,…
![]() Join Date: Nov 2002
I like the wheels!
Even though I think the grey centered version would fit that truck better. (Time to place another order,...)
#242 | |
#243 |
Do they make those wheels wide enough to fill out those rear fender wells?
79 Custom deluxe 250/th350 LWB- SOLD 87 Silverado 350/700r4 SWB - Daily Driver 57 Vw Beetle Ragtop |
#244 | |
Those don't look too bad. The steelies look better though ![]()
#245 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Put the steelies back on....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#246 |
love the look of the coys on there, but of course I am bias...
#247 |
I had some pretty stuff on my porch when I got home from work.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#248 | |||
![]() Quote:
![]() You don't think they'd grow on you?? ![]() Quote:
![]() Sweet!!!! ![]()
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-21-2010 at 06:10 AM. |
#249 |
PROJECT 7DEUCE
I like the wheels but I like the steelies on that truck better and I loved the old school welds ya had on it..
#250 |
I know what you're saying. There's just to many choices! Here's a comparison of tires. Definitely a difference, but the Coys/BFGs have a 12" tread width. I thinking I'm leaning towards the grey ones instead of the polished ones....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-26-2010 at 03:02 PM. |
