03-01-2010, 05:04 PM | #1 |
parts truck
here's a few shots of a parts truck i'm gonna pick up in a few days. hoping to use most of the front end to convert to disks, and 5 bolt pattern.
any ideas on carb brand? with some cleaning up, hopefully i'll be able to use most parts. general engine pic, the guy mentioned it was a 4 bolt 350, where do i find the stamp on the block? how do i tell which heads are on it? it has a twelve bolt rear end. do these numbers tell what gears are inside? or is there another tag? |
03-01-2010, 06:38 PM | #2 |
Re: parts truck
As far as the axle info I think you need to id the axle stamp numbers to find out what was in it stock.
Mark 1967 C/10 stepside lwb daily driver 1968 C/10 fleetside lwb parts truck 1971 Cheyenne Super swb project |
03-01-2010, 06:42 PM | #3 |
Re: parts truck
Carb is a factory replacement Holley, engine code will be on the driver's rear of the block behind the cylinder head, and the head numbers will be under the valve covers.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
03-01-2010, 08:08 PM | #4 |
its all about the +6 inches
Re: parts truck
3.07 gears is what it should have if still original
03-01-2010, 08:19 PM | #5 |
Re: parts truck
03-01-2010, 08:20 PM | #6 |
Re: parts truck
03-01-2010, 08:30 PM | #7 |
Re: parts truck
what about the front end parts? will the work to put on my 69? what should i be looking out for? this should bolt on?
03-01-2010, 09:57 PM | #8 |
Re: parts truck
3.07 gears are definitely cruise worthy, unless you go with an overdrive.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
03-01-2010, 10:06 PM | #9 |
Re: parts truck
03-01-2010, 10:07 PM | #10 | |
Under Construction
Re: parts truck
xmember in the frame, 12 of the 14 will line up when installing in the'69 , just elongate the other two and you will be on your way. Search the site there are several threads on it. Best of luck.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-01-2010, 11:13 PM | #11 |
Re: parts truck
A little tough to call from the two pics, but I don't see why not.
03-01-2010, 11:53 PM | #12 |
Re: parts truck
a couple more questions: the power steering and brake booster, these would be another couple of parts to take off the 72 parts truck for my 69?
i orginally planned on getting this parts truck for the windshield. |
03-03-2010, 09:43 PM | #13 |
Re: parts truck
how can u tell what it has by the # on the rear end , and what do u look for to tell ?
03-03-2010, 09:56 PM | #14 |
Re: parts truck
Those parts interchange also, you'd need to use a disc/drum master regardless.
