Power steering conversion hose routing pics?
Hey all.. Just curious if anyone has any pics of their power steering hose routing after converting from manual steering?? I just want to see what it's gonna look like under the hood..
![]() Thanks a ton!
My build thread: '66 Chevy |
Rollin' Old Skool
Re: Power steering conversion hose routing pics?
anybody have pictures of the routing? doesn't look like much room for hoses to fit underneath the inner fender, & i'm wondering if I'll need to trim/cut...currently in the process of converting mine, so any help is greatly appreciated
Sorry no pics but my fender was slightly bent up to just clear the hoses. I've often thought about trimming the inner fender but Ive just never had to. Seems to work fine with the bend. Doesnt look bad either
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
I put a 1/2 inch x 1 inch notch in my inner fender at the frame.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
The hoses on mine have several inches of steel tubing at the ends on the steering box. These easily route under the fender well and have plenty of room.
I don't have a photo available. |
originals had oval cutout in inner fender with a clamp that screwed to the inner fender
i drilled 2 holes using a hole saw in the inner fender to have the right angle on the hose to steering box
![]() Join Date: Dec 2010
Here is what i did, Im trying to keep from cutting the inner fender, I used the braided hose I was able to route thru an existing oblong hole in the frame, once thru the hole i attached fitting, looks like it will work and clear the fender
