Old 04-26-2010, 10:07 PM   #351
scotts62
One day...
scotts62's Avatar
Re: Project: Bad Bagged '68.5
Yeah, i like the Auto Meter Ultra lights but havent seen them to match them
Scott
93 crew cab build
Project 62
Old 05-04-2010, 10:20 PM   #352
jlaird
jlaird's Avatar
Well I haven't updated this thread with my dropmember purchase, so here goes. Back in December I got the bright idea to sell my sectioned crossmember and get a dropmember. So I had to pull the engine and trans to do so. While the trans was out, I sold that too! The money is going towards a Tremec TKO 600. I said to myself I'm building a hot rod, so why the hell do I have an automatic in here! It all felt like two steps backward, but I think the end result will be well worth it.
I got a flaming river power rack from Summit. All the dropmember pieces except the actual crossmember I powdercoated myself with an Eastwoods gun. That thing is awesome! So much better than dealing with paint that doesn't have he durability.
I also went ahead and got a swaybar from Nate.
The only thing that sucked about the whole deal was welding in the rack notches in an already powdercoated from. I took pictures of that but can find them. I felt like I was performing surgery!
A couple other notes for the record, I had to cut 1.25 inches off the ends of the rack. I also had to mill down one side of the AirRide upper control arms shafts because they were dished for the factory washer spacer thingys.
In this picture you can see the notch surgery.
Factory 73-87 brake calipers
jlaird is offline   Reply With Quote
Old 05-04-2010, 10:27 PM   #353
jlaird
jlaird's Avatar
Here are some pictures of the stainless hard lines for the air and brakes.
And the tools of the trade.
Old 05-04-2010, 10:32 PM   #354
jlaird
jlaird's Avatar
Here a couple pics of the cab repair that I found which I never posted.
Old 05-04-2010, 10:33 PM   #355
c10Mang
c10Mang's Avatar
insane work! I want a swaybar too now!! How was that to install?
c10Mang is offline   Reply With Quote
Old 05-04-2010, 10:42 PM   #356
jlaird
jlaird's Avatar
OK, back to the steering column. I wanted to make a reinforcement panel on the firewall where the column passes through. I gave me an excuse to use my REINFORCED harbor freight bead roller which is now a beast!
Here is the Flaming River Stainless tilt column and the Ididit mount.
Upper column mount is also from Flaming River.
Old 05-04-2010, 10:43 PM   #357
VA72C10
VA72C10
VA72C10's Avatar
Looking really good!
Old 05-04-2010, 10:43 PM   #358
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Hey Jlaird.....The clamps you are using for your brake lines and air line.....made 4 you brand ???? How rough a time did you have bending up the lines, did you make patterns out of steel before you did the stainless ? Any problems flaring the stainless other than having to have a 37 degree flare tool ? Sorry if you have answered the questions elsewhere. Tryin to decide what to do with mine.....really like the way you have yours layed out, gonna steel some of your Ideas.
ksbrktracer is offline   Reply With Quote
Old 05-04-2010, 10:45 PM   #359
jlaird
jlaird's Avatar
Here is the bead roller. I still want to add a steering wheel to it.
This is the back where I added the square tubing.
Old 05-04-2010, 10:49 PM   #360
jlaird
jlaird's Avatar
Some more holes filled on the firewall tunnel area.
Here is a pic of some ads I bought off ebay for the garage.
Old 05-04-2010, 10:52 PM   #361
ksbrktracer
TNT-MOTORSPORTS
One other question, your power brake booster...who's is it, what brand....I really like it too.
Old 05-04-2010, 10:58 PM   #362
jlaird
jlaird's Avatar
OK, time to smooth out the dash where the dash pad used to go.
I cut these out of a piece of steel exhaust pipe because they had the same curve as the dash.
Tacked in place.
Ground smooth. Yes, I'm a Jr. fan. LOL
Old 05-04-2010, 11:07 PM   #363
jlaird
jlaird's Avatar
Swaybar was a snap to install.
Yes, http://www.made4uproducts.com/ There is more info on bending stainless in this thread. I did buy steel lines from the local parts store and made templates with them before doing the stainless. It takes more time, but when you have a line with 100 bends in it and you screw up the last one, you will not be a happy camper!
The booster is a 7" diaphram from CPP as is the Master.
Old 05-05-2010, 12:00 AM   #364
Coda O'Dell
Coda O'Dell's Avatar
Got a part number on those shocks?
Coda O'Dell is offline   Reply With Quote
Old 05-05-2010, 07:45 AM   #365
scotts62
One day...
scotts62's Avatar
Looks good! I like what you did with the dash!
Scott
93 crew cab build
Project 62
Old 05-05-2010, 09:29 AM   #366
67cheby
67cheby
67cheby's Avatar
why dont you build some of those lines and sell them.... i would buy the first set !!
67cheby is offline   Reply With Quote
Old 05-06-2010, 08:23 PM   #367
jlaird
jlaird's Avatar
carquest 1924202
Thanks everybody for the compliments!
Old 05-07-2010, 01:02 AM   #368
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Looks good! I culled my sectioned crossmember as well along with my Zed frame. Started on the Dropmember tonight!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-07-2010, 01:19 PM   #369
68laydout
Junior Member
68laydout's Avatar
Damn nice man! Lookin' real good!
Cory
68laydout is offline   Reply With Quote
Old 06-05-2010, 09:25 AM   #370
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
My wife is similarly afflicted.....
Ghostwhite is offline   Reply With Quote
Old 06-05-2010, 01:50 PM   #371
trenz68
Damage Inc
trenz68's Avatar
looks like a good project
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold
01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame
04 RCSB-joe gibbs clone,22in billets
68 stepper build
http://67-72chevytrucks.com/vboard/s...d.php?t=332337
trenz68 is offline   Reply With Quote
Old 06-05-2010, 02:06 PM   #372
bigguy69
dazed and confused
bigguy69's Avatar
looks good!!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 06-05-2010, 02:45 PM   #373
SCOTI
SCOTI's Avatar
OK, back to the steering column. Here is the Flaming River Stainless tilt column and the Ididit mount.....
Wouldn't all that work to slick out where the column protrudes through the firewall hole appear better w/the nuts on the interior side of the firewall vs. the engine compartment side?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-05-2010, 02:49 PM   #374
67cheby
67cheby
67cheby's Avatar
that is a clean looking setup
Old 06-05-2010, 02:50 PM   #375
gixxerpymp
Very nice job man. Can't wait to see her finished.
Keep it up!
gixxerpymp is offline   Reply With Quote
