Porterbuilt rear trailing arms in my Burb
Picked up my parts from Nathan on Wensday and went to work.
2-20, 2-21 whatever it takes! |
Re: Porterbuilt rear trailing arms in my Burb
First things first I removed my stock trailing arms and my previous crossmembes. then losely installed the new X-member and trailing arms.
Next was the NOT FUN task of removeing the two rear factory crossmembers, I removed the lower rivits by cutting a # pattern with a die grinder and then used an air chissel to remove the heads and seperate the plates, this is easier on a pickup with the bed removed but nearly impossible on the burb. Next I cut the uppers with a plasma cutter, thank goodness for a plasma cutter. I thought the hard part was over then I began removing the wood and tubs. The wood wasn't so bad but the tubs.....once again "thank goodness for a plasma cutter". They dont come out any other way. Then I test fitted a notch...more to come Tuesday.
2-20, 2-21 whatever it takes! Last edited by Hickup pickup; 05-23-2010 at 07:02 PM. |
VA72C10
![]() Join Date: Mar 2008
cool! Looking good!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Squarebody guy
It is looking really good, one of these days I'll figure mine out too! Keep the pics coming
67-72 parts collector,…
![]() Join Date: Nov 2002
Subscribing!
Holy crap! That's a huge notch! Good work and thanks for the pics.
actually this is his small one!
Resistance is Futile
Nice work Rob....looking forward to seeing the finished project.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
By the way this is a before shot all the way down.
2-20, 2-21 whatever it takes! Last edited by Hickup pickup; 05-23-2010 at 11:17 PM. |
Thanks Jeff.
Argon User
It's going to look good all laid out.. still doing the 22 in the rear
As soon as they are availiable!
I'm fixing to start doing the same thing to my Burb. Cant wait to see the pics as you continue. Looks great so far....
-Justin |
#15 |
Who made the other cross member? I want a burb so bad. It's killing me. Yours is awesome. Keep up the good work. Looks like a pro!!
1966 C10, SB305, bagged. 1955 VW Buggy, 2.0L 1978 Honda CB550 http://67-72chevytrucks.com/vboard/s...9&goto=newpost |
#16 |
Was also a Porterbuilt, just an eairlier one
#17 |
That is a serious notch...lottsa o travel. fer sure! Get it handled. You gotta be done by sunday!
"Do what you want to the girl, but leave me alone!" |
#18 |
Decided to spend some time tightning my U-bolts tonight. You will need to invest in a 1-1/16 box end 12 point wrench, Don't buy a 6 point and an open end will not work and sockets are right out! I went to Sears and bought a new one for $21 with tax. When I got home it was a little tight so off to the local pawn shop (a great place to buy tools you need to modify or will only need once). I found one that was a little less bulky and paid $3 no tax, and promptly returned the Craftsman. Now I could cut, grind, bend and modify it any way I wanted.
#19 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
1966 C10, SB305, bagged. 1955 VW Buggy, 2.0L 1978 Honda CB550 http://67-72chevytrucks.com/vboard/s...9&goto=newpost Last edited by augie; 05-25-2010 at 11:51 AM. Reason: WTB by nonsub |
#20 | |
#21 |
Under Construction
XRATT asked to buy, and an admin (Augie) replaced XRATT's comments with the above.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 05-25-2010 at 12:35 PM. |
#22 |
Squarebody guy
Beat me to it, xratt made an inappropriate post and the admins replaced/erased it. Its not anything you posted Hickup.
#23 |
Gotch ya, Sorry bout that!
#24 |
Under Construction
Nice suburban by the way! keep plugging away at it......
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#25 |
Test fitting thr notches, gonna trim them down bout 3" then the welding begins!
