#51 | |
built not bought
Re: project: what ya doin that for?
Thanks for all the kind words guys. I will get some more pics up this weekend, I have made some progress and the truck IS back on the road! I have been busy getting the room ready for the new baby. Hes not due until august, but that is gonna be here before I know it ![]()
MY BUILD THREAD "project: what you doin that for?" http://67-72chevytrucks.com/vboard/s...d.php?t=382503 |
#52 |
built not bought
Ok, time for an update. with what little time I get with the truck (aside from driving it every day) I have got some stuff done. Carrier bearing dropped (still has a little shimmy). Little bumper units pulled off the front bumper, Driver window rolls down now. rear bumper on, exhaust scabbed on until I get the $ for some new flowmasters, and all the stainless trim off the rockers (what a PAIN!), and painted pinstripes sanded off. PICS!!!
#53 |
looks awesome man!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#54 |
Cool, truck I had an 88 crew long bed that I wanted to shorten but, never did.
My only question is why would you swap the 1 ton axles for 1/2 ton axles? The front could have been converted to single wheel and 14 bolts are inexpensive for the rear. Just curious. |
#55 |
very nice!!
I need a 4x4 CCSB too ![]()
#56 | |
built not bought
#57 |
I don't know how, but i have yet to see your build until just now. Now i'm looking for a donor 4x4!
![]() Very nice work man, keep it up! |
#58 |
6.0 powered square
looking good, I believe I like the looks of a 4x4 ccsb more then a 2x4 one mmm maybe I'll build one with 5.9 cummins
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#59 | |
#60 | |
built not bought
MY BUILD THREAD "project: what you doin that for?" http://67-72chevytrucks.com/vboard/s...d.php?t=382503 Last edited by tswore; 07-07-2010 at 12:20 PM. |
#61 | |
#62 |
so im heading down to my shop today to start stripping the bed and all the other crap off the truck so i can cut the frame to fit a short bed. did you cut 14'' out behind the cab?
#63 | |
built not bought
#64 |
thanks for the info... heading to the shop tomorrow to finish it up... its been sitting on jack stands and being held together with ratchet straps and c clamps for a week
#65 |
Anything new on this?
#66 |
built not bought
Ugh, not really
#67 | |
#68 | |
#69 |
Congrats guys, its hard to get much done on the trucks but there little smiles sure are worth every moment. Times flies by, its already been a year since I became a Dad. Have fun
#70 |
built not bought
WOW! its been a while since I have posted. Since august not much has got done to the truck. I did manage to tear up the rear end. All of the concerns of running a 10 bolt have tuned out exactly how I had feared. So after a little searching I found a 14 bolt SF axle from a 97 z71. This has a 9. inch ring gear and should be stronger than the 10 bolt. I have cut the spring perches off and got the axle tubes prepped to weld new perches on now. Also, I scored some seats from a 97 to put in the front, and found a seat and console from the parts yard for 70 bucks! I have the rear seat mounted and done, but have yet to finish do the fronts. The brackets on the rear were pretty easy to modify, but the fronts wont be quite as easy. unfortunately the stock brackets/sliders are different from those that ojoe had. I have a plan for them, but havent had the time to do it. I hope to be back on the project after a couple months of slacking, lol. The new baby boy is awesome, just turned months and is growing like a weed! here are some pics of the new rear end ready to be put in and the seats....
#71 |
Very nice!!
I want to find some seats like that for my crew! Posted via Mobile Device
#72 |
I'm jealous, I want a CCSB 4x4
#73 |
I love the seats in there man congrats
WillieloRidez Drive em in Drag em out! Projects: 1956 Chevrolet 210 2dr post 58 chevrolet 2dr delray 58 chevrolet belair 4dr hardtop 1965 Chevelle big block 4spd 88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=388445 |
#74 |
built not bought
Well, I finally got to work on the seats this weekend. I got the driver seat installed. The brackets werent too bad to do, I cut the rivets that held the steel bracket to the power slider assembly, bent up new brackets from 2.5 inch 3/16ths thick angle, and bolted the new brackets to the seat slider with new tapered head bolts. here are some pics of the finished prodct! next weekend I will do the passenger.
#75 |
built not bought
alright, i got the brackets built for the passenger side today. I took some 1.5 in by 2.5 inch square tube and cut it down similar to the angle on the other side. i then attached the slider assembly from the factory bracket to the new tube and bolted that down. I do need to shift the passenger side towards the door about 1.5 inches. So right now the seat is just bolted on the outside rail.
