Help ID'ing this- also a couple of pics of trk
I am doing a part by part frame off as my memory is not what it used to be....a total frame off at one time would be more parts than I care to remember....
So anyway Heres the wire. It looks like a ground but I am uncertain as to why a ground would be fused? Also included are a couple of pics of the old girl. This is my 6th or so of this species I have owned. I regretted getting rid of them all, but at the time money was tight...This one started off as a cam change and has grown far out of proportion from whence I started.... Thanks for your time |
"THE GREEN GOBLIN"
Re: Help ID'ing this- also a couple of pics of trk
that wire is from the lights it goes to the power junction block on th fender. Need a picture just let me know I will run out and take one for you... Also has a little fuse in it.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 06-10-2010 at 06:32 PM. |
Its not a ground its a bus line with a fuse inside of that football shaped housing. There is also one on the other corner. There is a small glass fuse in each and it goes on that two prong distribution block right there on the inner fender.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
It has been my understanding that this is is for the battery gage. I have never been sure if it should be ground or hot though.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
"THE GREEN GOBLIN"
It is "Hot" Not sure if its for the lights but it's in the same wire harness!
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
![]() Join Date: Jul 2001
Welcome to the board from Maryland! Looks like a great project too
![]() Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
member #16
![]() Join Date: Dec 1999
Welcome to the board. The 4A fuse holders are for the ammeter.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
From the diagram it looks to be just three different routes to bring power in, where it's distributed from there.......Assistance is greatly appreciated, somewhere I have a factory manual...I just can't put my finger on it right now.
The diagram may help later though I have most of it done. I am running alot of stuff off of relays. The interior wiring looks to be unmolested just lots of "extra" wiring from the previous owner. The 4l80 tranny is the next thing to tackle and looks to be a treat, then the box off and new cab corners. Why do I do these things. All I wanted was a daily driver? ![]() Ooops just caught your comment about the ammeter Last edited by llowlife; 06-10-2010 at 09:35 PM. |
Location: Aurora,Il ..born,raised and still live in the same house
one time i tried to start my truck and got absolutely nothing.No click, no turnover,nothing.
took me about an hour of trying everything and still nothing! until i finally messed with that junction and those 3 wires connected to it,wiggled it,tightened it up and bam! truck started right up.
I love stock! Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine) For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL |
