07-01-2010, 12:25 AM | #1 |
72 C30 Trailer Queen
1991 5 speed manual transmission w/overdrive
1991 5 speed manual transmission, from 2 wheel drive extended cab C1500.
Appears to be a New Venture Gear NVG5LM60. Includes flywheel/clutch assy., 2 piece driveshaft, shifter, and master/slave cylinder. $300 is the price. I will ship it, but I would guess it is not cheap...
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts Last edited by Chris H; 07-01-2010 at 12:27 AM. |
07-03-2010, 07:20 PM | #2 |
Re: 1991 5 speed manual transmission w/overdrive
Chris, I'm interested in the trans and stuff. But I will have to see what kind of a deal we can work up. I would pick it up in person, it getting time to take a trip again. If someone comes along before we can strike up some type of deal go ahead and sell it.
07-03-2010, 07:39 PM | #3 |
Chris
hey I was wondering how long is that trans from the bellhousing to block flange/motor side, to the end of the trans where the yoke goes in, in other words overall trans length including the bellhousing?
Also how long is that driveshaft when both pieces are together?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
07-04-2010, 10:39 PM | #4 | |
At any rate, for those intently following along at home: there is no deal until I post SOLD.
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
07-05-2010, 04:55 PM | #5 |
Chris
any measures?
07-06-2010, 11:19 AM | #6 |
Total trans length, face of bellhousing to tip of output shaft = 29.75"
Face of trans to mounting bolt = 26.0" Driveshaft: 3 pieces measured to center of u-joint shafts yoke = 6.75" (4.25" slips inside transmission) front shaft = 39.0" rear shaft = 44.5" From front shaft to rear shaft is a slip yoke, with at least 2.5" of safe travel available. Helpful?
07-06-2010, 12:26 PM | #7 |
Chris
sure does I had heard the trans was the same as a short tail th350 and it is.
Thanks for the info.
07-06-2010, 12:46 PM | #8 |
You mean you had no intention of buying???
07-06-2010, 01:43 PM | #9 |
Chris
no sorry, besides that I thought the other guy wanted it. it would not work for me anyways, being an 84 or an 88 4x4.
07-06-2010, 09:09 PM | #10 |
Chris, Sent you a pm about whats going on, and for the rest it is still up for sale.
07-19-2010, 08:40 PM | #11 | |
Bloo
i dont know if you have or would sell this piece seperate, but do you have the rod that goes into the back of the master cylinder?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
07-21-2010, 09:23 AM | #12 |
07-22-2010, 08:05 AM | #13 |
Sold locally.
