#1601 |
Senior Enthusiast
Re: What did you do to your truck today?
Nobody would ever guess all the work that went into it, looks just like new. Great job!
#1602 |
Well, nothing yet...but I plan on blasting the drivers' side radiator support tonight. Hopefully I won't have to work this weekend and will have time to blast a lot more parts.
-Mike from Alabama Why do we park on a driveway, and drive on a parkway? Jake - '67 Short Step Dirty Dan - '80 Short Fleet |
#1603 |
started cutting out the old floor for my patch panels
#1604 |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Leaned on the bed and looked at all the junk in the back. Thought, it's to damn hot outside to run to the dump with no AC in it. Went back inside and watched tv.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
#1605 |
Senior Enthusiast
Cleaned the stickers and goo off the new Gabriel gas shocks that just arrived, now shopping online for a toggle switch with an illuminated tip to use as a back up light indicator.
#1606 |
![]() Join Date: Aug 2009
Well...you would not think it would take 8 hours to prep 2 cowl corners but...I had 3 sets of these things, one set was rusted out on the top and were original to my truck, one set did not fit the truck right, the other had an 1 inch antenna drilled in with a 3/16 bit, so I ended up cutting the rust out on the original ones and repairing them, filled the emblem holes while I was at it, 8 hours later I have a set ready for final sanding and coating the inside with por 15, next step is repairing the hood !!
#1607 |
Checked the progress on the rear half of my fenderside yesterday. It may be painted next week.
#1608 |
Senior Enthusiast
Looks like you are well on your way to having it turn out as nice as your Henry J. It's nice to see one restored, since many of us make numerous modifications.
#1609 |
Thanks Mark! I only have $300 left in my fenderside budget for 2010. The painter wants another $200 but the paint, reducer and hardener have all been purchased. As well as all of the hardware. I changed my mind on the color and will not go with the original light gray, but will instead do ivoery over light blue. I am surprised you remembered that I owned a Henry J. Here is another image of that car.
#1610 | |
![]() Join Date: Sep 2006
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#1611 |
chevy only
after 20 years of owning my panel it now has a system (music) and my buddy lance at creative car hook it up,two huge 12" subs and 4 6x9s and two tweets,two huge xtants amps and i didnt do a deck it runs of my ipod, and sounds killer, he has done all my stuff for years,
CHEVY ONLY... Nothin Else ! Last edited by Dinos63; 07-18-2010 at 01:50 AM. |
#1612 |
Senior Enthusiast
Very productive today, added a chrome license frame to my rear plate.
#1613 |
I decided to find different fenders enoughs enough!
#1614 |
Sunburst C10!!!
i caught my truck on fire!!!
Gage 1967 C10 Shortbed Stepside |
#1615 |
Senior Car Nut
![]() Join Date: Jan 2008
yikes, you must have a Holley carburetor! Is the truck OK?
here's my effort over the past several days: ![]() ![]() ![]() ![]()
Larry Last edited by fleetsidelarry; 07-18-2010 at 06:37 PM. |
#1616 |
Senior Enthusiast
#1617 |
![]() Join Date: Nov 2009
disassembled my newly acquired SWB Fleetside bed. built an engine stand for my also newly acquired 283 to sit on. Otherwise, the 5 million degrees in the shade drove me back in the house. I am sure i won't be getting much done until around Oct when it begins to cool off some.
#1618 |
Sunburst C10!!!
the fuel line busted and was spraying fuel out at about 15 psi
i guess the starter sparked when i tried to start it and the passenger side of my engine bay was up in flames i immediately killed the fuel pump and ran for the fire extinguisher it took two of them the only damage it did was burn the battery cables and the whole engine bay is covered in dust from the fire extinguishers
#1619 |
![]() ![]() Join Date: Nov 2008
What are these lights from originally? I feel like I remember them from one of my Dad's cars but I can't remember which one.
#1620 |
Ran the fuel & trans lines, bolted on the ramhorns, exhaust pipes, starter. Now to fix the main wire harness, bolt on kick-down bracket, carb n valve covers connect radiator. Should be ready to fire this up next weekend!
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
#1621 | |
Senior Enthusiast
#1622 |
Thanks for the info on the B/U lights!! They look great on yer stepside!
#1623 | |
If it has tits or wheels its gonna give you problems!!! |
#1624 |
![]() Join Date: Jun 2009
put the new floorpan on the roof of the truck,...just for storage...til i can afford to put it in...
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
#1625 |
worked on one door all day, got it stripped to bare metal worked the dents out and gave it a few shots with epoxy and blocked it down, ready for another coat and the guide coat, man these trucks have a lot of surface area !! one down one to go !!
