Old 09-27-2010, 06:12 PM   #1
Puglia10
need some frame pics please
Hey guys, the mounts on my frame for the cab/bed are rotted, I was going to have my welder just weld a washer in but I was just reading somewhere the pre-81 frames (mine is an 80) had "D" shaped holes and not circular. Can anyone confirm, post up a pic or measurement? I gotta get these fixed somehow. Thanks! Its a regular cab short bed 2wd if that helps.
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 09-30-2010, 12:39 PM   #2
Puglia10
Re: need some frame pics please
bump! need to figure this out before he welds it, thanks
1979 c30 3+3 dually
1946 GMC
Old 09-30-2010, 01:11 PM   #3
benoit454
Chris
benoit454's Avatar
there are tons of build threads in this sections and lots of frame off, I'd look there and see what you can find.
http://67-72chevytrucks.com/vboard/s...345612&page=79
http://67-72chevytrucks.com/vboard/s...327474&page=11
that's 2 right off the top of the list that have frame off pics and such. if nothing else pm them or reply in their threads, from what I've seen they look round. Why would d shaped or round matter? Body mounts I'd guess? Also they are pretty good sized holes can ya get washers with a huge hole like that in them?
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 09-30-2010, 02:07 PM   #4
Moostifer
a fool with no money
Moostifer's Avatar
looks like the two in front of the axle are oblong shaped across the frame...
and the rear are oblong shaped with the frame...
i could be wrong...
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 09-30-2010, 03:35 PM   #5
benoit454
Chris
benoit454's Avatar
that's the bed mounts they ARE oblong definately, to allow you to move it forward. I think he meant cab mounts and front rad. support mounts.
Chris
GIT R DONE!!!!!!
Old 09-30-2010, 05:43 PM   #6
Restrorob
The One And Only !!!
Restrorob's Avatar
My 74 has round holes on the cab and core support mounts, Took pics but forgot my camera program isn't loaded in this back-up computer....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 09-30-2010, 06:32 PM   #7
tazman87
tazman87's Avatar
back cab mounts are circular.
tazman87 is offline   Reply With Quote
Old 09-30-2010, 06:35 PM   #8
tazman87
tazman87's Avatar
wont matter whether they are circular or D shaped. as long as the cab mount is pressed securely and even on the washed that you had welded on that it won't go anywhere. and i would just tac the washers on first then drop the cab to see if it lines up good then weld the sucker on. and weld it solid or put silicone on to prevent rust coming through the washer.
2nd that, just center the washer on the width of the mount, should be good
