Old 09-28-2010, 11:50 PM   #1
05crewcab
05crewcab's Avatar
8-400 badge...what exactly does it mean?
Just want to make sure of something. the 8-400 badge came out in 71 for the big block trucks even though they were infact 402ci, and, eventhough the '70 trucks were 402's, they still got the 8-396 badge correct?
And, the small block 400 was never offered in the pre-'73 trucks, true?
I ask because I might buy this truck below (for the motor and tranny, and onl y if I can get it cheaper) and can't quite make out the size of the motor in the pic, and I think it is a '72, not a '70:
http://minneapolis.craigslist.org/hn...955810491.html
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 09-28-2010, 11:56 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 8-400 badge...what exactly does it mean?
That is a 72 big block. (402) In 1970 they were badged as 400 thru 72.
And you are correct the 400 small block wasn't offered in these trucks. That looks like a good buy. Better hurry, won't last long.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-29-2010, 12:20 AM   #3
05crewcab
05crewcab's Avatar
Thanks man...that's what I thought...now if only I can con the wife into thinking this is a good idea
Say, this ad in craigs is from your neck of the woods...you thinning the herd?
1967 chevy shortbed parts truck - $500 (Grand Rapids)
1971 C-20 350/350
Old 09-29-2010, 12:53 AM   #4
7dguy
These trucks are funny. The spid sheet in the glove box sometimes say they are 396. The badge says 400, yet they are a 402. Funnier yet is they barely put out over 300HP! Good news is they respond very well to larger cam's and can actually perform a bit when coaxed. You've found somewhat of a rare truck, I'd buy it if it runs.
7dguy is offline   Reply With Quote
Old 09-29-2010, 01:41 AM   #5
sleepertruck72
sleepertruck72's Avatar
I would buy it
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 09-29-2010, 08:48 AM   #6
too much stuff
Roadtrip!
I have been thinning the herd for over a year now. Still have a few to go... And yes, that is one of mine.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 09-29-2010, 10:28 AM   #7
05crewcab
05crewcab's Avatar
Cool, good to know. You have a bunch of parts too, or just some carcasses left? I'm in the market for a few things...
1971 C-20 350/350
Old 09-29-2010, 10:29 AM   #8
05crewcab
05crewcab's Avatar
So, if the guy doesn't have a key for it, how am i to get it running? bridge a wire from the battery to the starter? then likewise, how do i get it to stop running? block the carb?
Or is there an easier way?
1971 C-20 350/350
Old 09-29-2010, 01:13 PM   #9
sleepertruck72
You could use a screwdriver and bridge the connections at the starter to see if it will start, or if you prefer simplicity, replace the ignition switch cylinder. Then you will have the keys
72 C20 Longbed
05 1500 Z71
Old 09-29-2010, 01:25 PM   #10
JET4x4
Looks like it has a tilt column also...
67 Chevy K20 LWB Fleetside project
85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project
86 m1009 blazer, 6 in lift, 35's, driver
69 c10, 307, long bed, 3 speed, driver
07 Dodge 2500, cc, lb, cummins turbo diesel
00 z28 camaro, ls1, 6 speed, rarely leaves the garage
JET4x4 is offline   Reply With Quote
Old 09-29-2010, 01:46 PM   #11
05crewcab
05crewcab's Avatar
It does! the guy just sent me more pictures and it looks pretty good...now i am getting excited
1971 C-20 350/350
Old 09-29-2010, 05:21 PM   #12
shiner2001
shiner2001's Avatar
I'm new around here, but I'm pretty sure that the screw in the upper part of the door, just below the vent window handle tells you it's a 72. Obviously, that's assuming it's all original, but it's a start. Someone correct me if I'm wrong on that one...
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 09-29-2010, 05:41 PM   #13
Rodk65
Rodk65's Avatar
Its a 72. He sent me the VIN and a couple of pictures.
Name:  70 Chevy trucks 003.jpg
Name:  70 Chevy trucks 001.jpg
Name:  70 Chevy trucks 009.jpg
ROD
1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C.
1971 C20 Camper Special. 350/350. SOLD
2002 Chevy Tahoe LT
Rodk65 is offline   Reply With Quote
Old 09-29-2010, 05:57 PM   #14
tkeduk8r
tkeduk8r's Avatar
BUY IT before i have to!!! bb, tilt, D60, fact aux tank, vintage turbines... needs a hom eto some one on this board...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 09-29-2010, 06:39 PM   #15
Rodk65
Rodk65's Avatar
I'm thinking about it. I'm trying to figure out what to do about the title, or just switch cabs. Just have to make the 5-6 hour road trip.
ROD
2002 Chevy Tahoe LT
Old 09-29-2010, 07:04 PM   #16
darush01
If you are just going to use it for parts I'd just take a screwdriver and knock the ignition out and start it like tht I think it would work I drove my 85 3/4 ton and my 78 elcamino with a screwdriver for a key for a while
darush01 is offline   Reply With Quote
Old 09-29-2010, 08:00 PM   #17
raycow
If you only want to see if the engine will start, run a wire from the battery (+) to the ignition coil (+). Then jump the starter solenoid (bat to S terminal) with a heavy screwdriver. If you want to do it "nice", clip a remote starter switch onto the solenoid instead of using a screwdriver. Don't run the engine for very long like this if the distributor still has points, because they will burn very quickly.
If the distributor has points and you want to run the engine for an extended length of time, connect an external coil resistor in series with the battery to coil wire.
Ray
raycow is offline   Reply With Quote
Old 09-29-2010, 10:05 PM   #18
05crewcab
05crewcab's Avatar
--Mike
I've got dibs! we can have a race to the truck on Saturday tkeduk8r, you have to give us a little bit of a head start!
1971 C-20 350/350
Old 10-02-2010, 10:23 PM   #19
05crewcab
05crewcab's Avatar
Well friends, I got it
I didn't get it started because it has points and I didn't want to fry them, so I took a leap. The oil wasn't too dirty, and the trans fluid was clean as can be. The tilt wheel is tight, all the AC components are present except the compressor it seems, and the frame doesn't look NEARLY as bad as the body.
The cab and bed are pretty rotten, and the old turbines (9.5x16.5) are 'ok' but the tires are shot/missing It also has all the camper stuff on it still (wiring, tie-down posts, etc.)
It isn't as nice as I had hoped, but I am going to see what I can do to improve that. I am going to clean it tip to tail and get it running. then i will decide if I want to re-sell, or part it, or put the body of my 71 on this frame/drivetrain.
1971 C-20 350/350
Old 10-02-2010, 10:26 PM   #20
05crewcab
05crewcab's Avatar
more...
1971 C-20 350/350
Old 10-03-2010, 12:16 AM   #21
Rodk65
Rodk65's Avatar
I'm glad someone went to get it. Were any of his other truck any good?
ROD
2002 Chevy Tahoe LT
Old 10-03-2010, 04:02 AM   #22
05crewcab
05crewcab's Avatar
The '70 c-20 was ok, probably the same level as this truck, and I didn't look to closely at the '64's, except the c-20 dually looked like it was a 67-72 coil rear frame with a dually HO72 rear axle, no box.
This guy is retired and gets 2 to 10 cars daily from people that are running estates or want to clear up the clutter on their farmstead. he generally just scraps them @ about $175 a ton unless they are unique/in better shape than normal.
Funny thing...i had just loaded the truck up on the trailer and parked it on the service road next to the freeway to then settle up with the seller, and some dude pulled off the freeway and stopped by my truck. he then went on to say that he saw the truck loaded up and had to stop because he has a '67 small window short box sitting at his place that he wants sold. We exchanged contact info and I said I would post some pics here for him if he'd like. we'll see if he emails me... These trucks are waiting for us obsessive bastards all over the place
1971 C-20 350/350
Old 10-03-2010, 11:31 AM   #23
too much stuff
Roadtrip!
Glad someone from here got it. Did you get a deal? Lots of good parts there...
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 10-03-2010, 11:37 AM   #24
tkeduk8r
tkeduk8r's Avatar
GOOD JOB!!!! I wasnt looking forward to marraige counselling if I diverted our trip to the twins game yesterday to go look at it ...
--Mike
Old 10-03-2010, 07:34 PM   #25
05crewcab
05crewcab's Avatar
I got an ok deal on it...I offered him 5 bills initially and we ended up in the middle.
--Mike
Yeah, I hear ya! In 7 months I went from having no old trucks to having two...the wife is putting together her list of demands as we speak...
Got it cleaned up today... there was moss EVERYWHERE:
1971 C-20 350/350
