10-07-2010, 03:26 PM | #1 |
DANA 60 front drive shaft lenght?
Im swapping out the 44 for the 60. Long time coming!
Does anyone know if I'll be able to use the 44 driveshaft or will I have to do something to make it work? shorten it? Thanks for the help 1985 3/4t turbo 400 and stock transfer case.
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
10-07-2010, 04:54 PM | #2 |
Re: DANA 60 front drive shaft lenght?
I have a friend that did this swap (3/4 ton dana 44 to dana 60) and the front drive shaft was the same.
10-08-2010, 07:11 AM | #3 | |
Im looking to swap her and start plowing with her soon!
10-08-2010, 10:08 AM | #4 |
Honestly, I think It depends on the year. We had a 79 K30 we robbed the 60 out of swapped in a 84 8 lug 10 bolt and resold the truck. The joints were not the same. You should be able to get a combination U joint if they don't match though.
10-09-2010, 01:39 AM | #5 | |
thanks for any help . (1988 1 ton crew cab ex army cv30943) |
10-09-2010, 01:57 AM | #6 |
Chevy Enthusiast
1 tons came with Dana 60s. The easiest way to tell is to look at the passenger side spring pad, dana 44s have two U bolts and 60s have one U bolt and two regular bolts.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
10-13-2010, 11:51 PM | #7 |
thanks , looks like i have a 60 on mine . im now looking in to getting an overdrive trans and keeping the 4:10 gears . my boss knows someone that may be able to hook me up . then if i can sell my 3 speed it shouldnt hurt to much in the wallet department . trucks not to bad around town but cant really go above 55 on the highway , just need to get those revs down .
10-14-2010, 12:06 AM | #8 |
Chevy Enthusiast
Is it a 6.2?
10-14-2010, 12:14 AM | #9 |
10-14-2010, 07:22 AM | #10 |
Quick question, how many leaf springs do you guys have up front? the Dana I got has three from a dually.
My buddy has an 86 K30 reg cab SRW with 5 or 6 up front. Is this aftermarket?
10-14-2010, 01:35 PM | #11 |
Chevy Enthusiast
I think my K30 has three.
10-14-2010, 02:37 PM | #12 |
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
10-14-2010, 02:46 PM | #13 |
Driveshaft: I would check to see that the shaft has 1" or so of additional compression by removing the ujoin u bolt and compressing it. If it does not have at least 3/4" of additional compression I doubt it will work. If you are planning to or already have installed a lift kit of 4" or more then it will probably extend or is extended enough for the 60 to fit just fine. My guess is it has room for that much compression.
Leaf spring: 3/4 tons typically had 2 leaf fronts, but some heavier GVW setups had 3 front. 1 tons typically had 3, however I had one (SRW) that had 2 and assume it was a lighter GVW 1 ton. (think it was 9200 or 9300#) I have also heard of a Heavy chassis package that gave 4 leafs ( I think this was a wrecker package) and have seen a couple of them all were chassis and cab trucks. Not aware of 5/6 leaf setups on K30's, not saying they never existed but if they did they were very rare. |
10-14-2010, 03:46 PM | #14 |
Chevy Enthusiast
I looked at it and it has 4 in the front,9 in the rear with 2 overloads.
10-16-2010, 03:14 PM | #15 |
3 in the front, 9 in the rear.
Paul Waddell 1986 K30, Crewcab, Longbed, SRW (Ex-Airforce Truck) Front Royal, VA |
10-16-2010, 09:04 PM | #16 |
3 in the front and 16 in the rear. It used to be a TOW TRUCK!!!
