Closed Thread
Old 12-06-2010, 12:04 PM   #2176
az65
az65's Avatar
Re: What did you do to your truck today?
rebuilt master cylinder, put tires on the front and she is back on the road again
'65 long-bed with 327/3spd
'05 SRT-10 quadcab
'69 Superbee clone
'66 Charger w/ 36k og miles
and a handful of bimmers
az65 is offline
Old 12-06-2010, 12:16 PM   #2177
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I did the Tractor Supply Trac Bar mod this weekend.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 12-06-2010, 01:07 PM   #2178
markeb01
Senior Enthusiast
markeb01's Avatar
Originally Posted by 60apache View Post
just curious what is the purpose of this?
For me the biggest advantage would be closing the doors easily with the vents and windows shut. My doors close super easy with just a vent window open, but when they're all closed it's so air tight it's hard to get the doors shut without slamming them.
markeb01 is offline
Old 12-06-2010, 07:02 PM   #2179
blackmopar
got some stuff finished in the engine bay with my helper and got her running finally. Now just need to figure out my headlight problem!
blackmopar is offline
Old 12-06-2010, 07:13 PM   #2180
Indian113
Indian113's Avatar
Originally Posted by StevieC View Post
Plus what do you do for license plate lights if you don't have a bumper... or a smooth bumper?
Go to your local Harley shop and buy some lighted license plate bolts,I am going to put mine on when I get my rollpan mounted
Indian113 is offline
Old 12-06-2010, 07:28 PM   #2181
lakeroadster
Originally Posted by blackmopar View Post
got some stuff finished in the engine bay ...
Man that gold motor looks sweet with all the black accents.
Are you going "Heater Delete"?
lakeroadster is offline
Old 12-06-2010, 08:19 PM   #2182
losthope
losthope's Avatar
picked up a super straight bed for the 63! traded a pos 64 falcon parts car and $100 bucks i figured it was a good deal didnt cost to much and got a car outta my backyard guy wanted $300 at first
losthope is offline
Old 12-06-2010, 08:41 PM   #2183
blackmopar
thanks Roadster - yes no heater - its a socal ride! I do need to get the windshield wipers working I suppose since this is supposed to be my rain vehicle - LOL
Old 12-06-2010, 09:54 PM   #2184
losthope
losthope's Avatar
Originally Posted by markeb01 View Post
In spite of ambient temps in the mid 20’s, I managed to get my front wheels painted with the help of a couple of heat lamps.
i like them! and i like all the labeled storage tubs in the background good idea!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline
Old 12-06-2010, 10:45 PM   #2185
markeb01
Senior Enthusiast
markeb01's Avatar
I’m very big on organizing and labeling “everything”. I learned long ago, if you can’t find it when you need it you might as well throw it away - because you’ll just end up having to buy a replacement anyway. And it's really not all the difficult or expensive.
markeb01 is offline
Old 12-06-2010, 10:46 PM   #2186
60apache
60apache's Avatar
Short Answer:
Air vents, flow-through ventilation. Vents were from a modern Dodge ram.
Sales Brochure Answer:
A truck cab ventilation system and method which includes an air exhaust at the rear of the cab. An inlet vent in the front of the cab (kick panel vent) produces a positive pressure within the cab which causes flow-through ventilation air flow from the front to the rear of the cab when the truck is moving. . The exhaust vent includes flexible louvers of elastomer which are held by gravity in a closed position and are moved into an open position when air flows out through the exhaust system.
I take it you dont have a/c
60apache is offline
Old 12-06-2010, 11:25 PM   #2187
Chevy Fleetside
Chevy Fleetside's Avatar
[QUOTE=blackmopar;4335003]got some stuff finished in the engine bay with my helper and got her running finally. Now just need to figure out my headlight problem!
Whats wrong with the headlights. If they don't work check the plug that is at the radiator support. If that is clean inside maybe you have a bad highbeam switch. Make a jumper wire to check that one out. Most of the problems with the headlights is the connector at the radiator support.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 12-07-2010, 02:50 AM   #2188
PAPA KENT
PAPA KENT's Avatar
pulled it back in out of the snow,pulled the left fender off and cut off the bottom,pulled the glass from the doors,looked at it a while,took the doors and fender into town for repair.
PAPA KENT is offline
Old 12-07-2010, 03:22 AM   #2189
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Painted my bumper.
kalirodding is offline
Old 12-07-2010, 10:23 AM   #2190
Real_McCoy
Real_McCoy's Avatar
Installed my "CaptainFab Power Steering Adapter Plate" and moved the 64 and 66 outside for shop cleaning/organizing. The PO installed power steering, but the geometry was all wrong. Problem solved! The install was super easy, especially since the steering shaft was already cut down to the proper length and two holes were correct. Drilled two more holes in the correct position and mounted her up. Stitch welding will come when I tear the truck down for a frame off. Early 2011 I will start the process. I want to get the title work done before I do too much to her.
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline
Old 12-07-2010, 04:12 PM   #2191
markeb01
Senior Enthusiast
markeb01's Avatar
Turned out nice. There are times I wish I had kept mine and had it powder coated gloss black.
Originally Posted by kalirodding View Post
Painted my bumper.
markeb01 is offline
Old 12-07-2010, 06:28 PM   #2192
lakeroadster
Spray bombed the interior (<$10). Much better than the flat black the PO shot on it, it is close to original and good enough for my beater shop truck.
Didn't do the doors yet since they need fuzzies and glass channel weatherstripping.
So tell me gang, where is the OEM paint cut line at on the doors where it transitions from fawn to the cab color(s)?
Old 12-07-2010, 06:47 PM   #2193
markeb01
Senior Enthusiast
markeb01's Avatar
That looks great.
markeb01 is offline
Old 12-07-2010, 08:13 PM   #2194
fink64
whats the little boxes on the back wall for?
fink64 is offline
Old 12-07-2010, 08:16 PM   #2195
StevieC
Vents
now I want to leave early and work on my truck!
but instead I'm going to have to sit here at my desk and watch the Big Lebowski on netflix
StevieC is offline
Old 12-07-2010, 08:36 PM   #2196
Bugeyev8
Bugeyev8's Avatar
on my 62 which had never been painted was interior color around all sides of the door and the jambs were the exterior color , paint on your interior looks great, what color you going on the camaro dash ?
Bugeyev8 is offline
Old 12-07-2010, 08:54 PM   #2197
lakeroadster
Thanks for the info.
Camaro dash will be the same color shown in above photo. Gauge panels will be black, as well as the steering column, seats and console.
Old 12-07-2010, 09:20 PM   #2198
65Gregg
65Gregg's Avatar
Lakeroadster, how many cans so far?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 12-07-2010, 09:44 PM   #2199
shortbed70
shortbed70's Avatar
Put on a fender to see how it would look and check clearence.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline
Old 12-07-2010, 09:52 PM   #2200
kirtzen
kirtzen's Avatar
I finally put power steering in my truck.
kirtzen is offline
Closed Thread
