Old 12-17-2010, 04:54 AM   #1
dalfy1505
What to do trans prob
my 73 gmc jimmy 4 inch spring lift 350 th350 np203.
trans has been acting up finaly lost 2nd gear today i have a th350 np205 out of a 72 with driveshafts but trans was last run 20 some odd years ago. so should i rebuild the np205 trans and instal or try and find a different trans
dalfy1505 is offline   Reply With Quote
Old 01-04-2011, 08:45 AM   #2
Mkcustums
Mkcustums's Avatar
Re: What to do trans prob
86 people read this and no one has anything to offer for help?
I wouldn't bother trusting an auto trans that has been sitting for 20 years. If you just wanna try to get it running again maybe find a good used trans and clean it up a little and install that. Then if you want maybe have the 350 rebuilt but the 205 should be fine without a rebuild. I have never had to rebuild a 205 or had one break.
This was posted the 17th so maybe you have already figured something out.
Mkcustums is offline   Reply With Quote
Old 01-13-2011, 11:40 PM   #3
Space Truckin'
Space Truckin''s Avatar
I think I'd hunt up a used TH400 that will mate to your T-case and run with it. Maybe have it rebuilt, mine was only $750 to rebuild. Its a little stouter trans and they are only a couple hundred bucks for a good used one. Make sure you get one that was recently pulled, preferably one you can see run and shift then pull it yourself or let them.
Space Truckin' is offline   Reply With Quote
Old 01-15-2011, 08:14 PM   #4
dalfy1505
yea thanks i found a nv4500 3rd gear synchros are worn but for 200 i couldnt pass it up im gonna do a auto to standard swap n when im a little better of use that nv for a core on a reuilt one
Old 01-20-2011, 12:24 PM   #5
Space Truckin'
Not to shabby! I wish I could pick one up that cheap! I'd do a swap in mine in a heartbeat!
'91 Burb, Fuelly, The Caddyshack
'85 3+3 Duelly, Guzzler, Hank the Tank
