Old 01-27-2011, 07:22 PM   #1
JJanzen
JJanzen's Avatar
Restoring Upper and Lower Trim
It seems like about a year ago, someone did a write-up on restoring the side aluminum trim. For the life of me, I cannot find it now. If anyone has a link to it, I would appreciate it! Thanks.
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 01-27-2011, 07:42 PM   #2
BlackTopMotors
Re: Restoring Upper and Lower Trim
I will be getting to that soon...just cleaning an polishing for now
BlackTopMotors is offline   Reply With Quote
Old 01-27-2011, 07:46 PM   #3
DT1
DT1's Avatar
I restored my trim on my 71 Cheyenne about a year ago.
It takes a lot of time and patience but it can be done.
After removal I stripped all of the paint with Jabsco paint remover (Home Depot). Then I stripped the anodizing off with a solution of sodium hydroxide (Lye) and water 20:1.
I know that some guys here have had good luck with easy off oven cleaner or white lightning but it didn't work very well for me. I sprayed on the solution and worked it off with a scotch brite pad in just minutes. Once the aluminum is bare the dents can be worked out with a screen door roller and then sanded smooth. The high gloss is restored by using a denim buffing wheel and black cutting compound followed by a medium hard cotton wheel and brown or red compound. I then wiped the residue off with lacquer thinner. Finish by either applying a good grade of automotive clear coat or re-anodizing. I clear coated mine and it is holding up well. The black is SEM trim paint. and the wood grain if desired can be got from LMC Etc.
Before...
After...
DT1 is offline   Reply With Quote
Old 01-27-2011, 07:49 PM   #4
Fastfun
Fastfun's Avatar
That look's nice. That was a lot of work but it paid off!!!!
Fastfun is offline   Reply With Quote
Old 01-27-2011, 07:51 PM   #5
BlackTopMotors
That's good to know and looks great as well.
Old 01-27-2011, 08:20 PM   #6
DT1
DT1's Avatar
Here's the grill...
Before...
During...
After...
Old 01-27-2011, 08:31 PM   #7
BlackTopMotors
That is perfect for where I am at in the restoration process. I just finished cleaning and polishing the front...what did you use for the black inlays and such?
Old 01-27-2011, 08:33 PM   #8
bosco200
bosco200's Avatar
How did you get the scratches out of the grill?
bosco200 is offline   Reply With Quote
Old 01-27-2011, 08:52 PM   #9
JJanzen
JJanzen's Avatar
DT1,
Now that I see your pictures your write-up comes back to me. Thanks for showing us how to do it again!
Blue72
Red72
Old 01-27-2011, 08:58 PM   #10
FL71C10
Wow, very nice!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 01-27-2011, 11:03 PM   #11
19seventeeCustom
nice work,, that grill looks amazing!
19seventeeCustom is offline   Reply With Quote
Old 01-27-2011, 11:31 PM   #12
DT1
DT1's Avatar
I applied SEM 39144 Trim Black. To make it stick I applies a fog coat of automotive clear coat first and then put the black on. I followed it up with two more coats of clear.
Old 01-27-2011, 11:37 PM   #13
DT1
DT1's Avatar
After removing all of the dents and imperfections I sanded the entire grill with 400 followed with 600 grit wet/dry paper. Then it was buffed with a denim wheel with black cutting compound. I followed that with a medium cotton wheel with a finer brown compound. Others recommend jewelers rouge but it seems to me that it fogs it up too much. The wheels and compounds can be purchased from http://www.caswellplating.com/buffs/
Old 01-27-2011, 11:47 PM   #14
DT1
DT1's Avatar
Here's a couple of finished shots.
Old 01-28-2011, 12:23 AM   #15
VA72C10
VA72C10
VA72C10's Avatar
Awesome work!!!
Old 01-28-2011, 12:23 AM   #16
VA72C10
VA72C10
VA72C10's Avatar
I have a box full of trim and a few rolls of the woodgrain....Looks like I have some work to do
Old 01-28-2011, 12:48 AM   #17
BBrendal
Recalculating.....
BBrendal's Avatar
Before...
After...
Did you clear the moldingds first and then paint theblack or apply the black paint first and then clear? Im sure the woodgrain went as the final step. Right?
Brian - (BBrendal)
1969 Chevy Camaro Z28
1972 Chevy Blazer CST
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline   Reply With Quote
Old 01-28-2011, 01:01 AM   #18
DT1
DT1's Avatar
I fog coated the moldings with clear first to make the black stick. Then I applied the black and followed it up with two more clear. The wood grain tape was the last thing that went on with no over coating.
Old 01-28-2011, 08:20 AM   #19
BBrendal
Recalculating.....
BBrendal's Avatar
Thumbs up Re: Restoring Upper and Lower Trim
Did you use a hi gloss or semi gloss clear? They turned out great!
Brian - (BBrendal)
Old 01-28-2011, 11:57 AM   #20
DT1
DT1's Avatar
It's high gloss. I wanted the aluminum to shine like new. The black should be more of a semi gloss and I could have gone over it with a matte but I actually like it better shiny.
Old 01-28-2011, 01:29 PM   #21
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Awesome job!!! When you used the screen roller what did you use under the trim, just a table or a soft cloth?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 01-28-2011, 01:42 PM   #22
matthew20061
69' Chevy Stepside
matthew20061's Avatar
That grill and trim turned out awesome! Now I am going to have to try and do my grill with that, it needs a new one because its faded and there are lots of scratchs.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-28-2011, 02:00 PM   #23
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Did you do anything to the egg crate grille?
How much time do you have in this.
Does anyone know if the original mdgs are significantly better than new repop?
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 01-28-2011, 02:17 PM   #24
JJanzen
JJanzen's Avatar
Do a search on threads started by DT1. He went through step by step instructions on how to re-finish the grill. He addresses the insert in that write-up.
Blue72
Red72
Old 03-10-2011, 12:46 PM   #25
JJanzen
JJanzen's Avatar
I was going to start the stripping process this weekend on all the upper and lower trim and I thought I would just call around to several anodizing shops in Denver and see if they offered any advice. I found a shop called Finishing Pros and they indicated, if I would strip the paint and vinyl, they would strip the anodizing on all (20) piecs for $ 35.00. Then, once I polished or finished with scotchbrite, they would re-anodize all (20) pieces for $72.00. Sounds almost too good to be true!!! I sure am glad I made the call and think I will try this method out and will report back once I have completed the process.
Blue72
Red72
