Old 02-10-2011, 10:36 PM   #1
REDNOSE65
REDNOSE65's Avatar
60-66 outer rear view placement...
I need to locate the outer rear view mirrors. I purchased brand new after market mirrors and need to know where to place them...
Need measurements/placement.
Thanks in advance.
Jesse
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline   Reply With Quote
Old 02-11-2011, 12:58 AM   #2
66Z71
66Z71's Avatar
Re: 60-66 outer rear view placement...
What kind of new ones? are they repros of the stock ones?
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera
66Z71 is offline   Reply With Quote
Old 02-11-2011, 09:38 AM   #3
jbgroby
jbgroby's Avatar
If you're talking about the standard stock mirrors, the drivers door had factory welded nuts on the inside. The Pass. door has a plate with the holes pre-drilled all you need to is punch through the otter skin. My doors are being painted right now and the painted had to sand down through the bondo layer so I can see where to drill out the holes.
Hope this helps, if you look in your door you should be able to see the plate I'm speaking of.
jbgroby is offline   Reply With Quote
Old 02-11-2011, 11:33 AM   #4
REDNOSE65
REDNOSE65's Avatar
Here's what I have:
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 02-11-2011, 12:08 PM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 02-11-2011, 12:36 PM   #6
REDNOSE65
REDNOSE65's Avatar
Thank you every one. The holes were welded shut. I will have to use the original screws with nuts inside the door. I'm trying to figure out where exactly to mount them...as close to the original place as possible.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 02-11-2011, 12:47 PM   #7
jbgroby
jbgroby's Avatar
I hate when PO's do stupid stuff like that, BUT having said that it was HIS truck to do what he wanted.
If thats the case, take the drawing above and just move them down 3/4-1" and put 3 holes in the skin and use either lock nuts or lock washers and nuts I have to do this on my passinger side.
Old 02-11-2011, 12:50 PM   #8
Clyde65
Clyde65's Avatar
I just reached through the inside of the PS door and used a punch that you push on and it pops to make the dent, then repunched from the outside and drilled the holes.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-11-2011, 12:52 PM   #9
REDNOSE65
REDNOSE65's Avatar
Thanks fellas.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 02-11-2011, 01:09 PM   #10
Clyde65
Clyde65's Avatar
red, if you want you can take a pattern off mine, LMK.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-11-2011, 01:12 PM   #11
REDNOSE65
REDNOSE65's Avatar
Thanks. I'd like to...where are you located Clyde?
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 02-11-2011, 02:59 PM   #12
Clyde65
Clyde65's Avatar
I am located in south Ft worth. just west of Mansfield.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-11-2011, 03:11 PM   #13
markeb01
Senior Enthusiast
markeb01's Avatar
I'd recommend using serrated flange nuts inside the door. They won't fall through a box wrench and are easier to manage one handed than lock washers:
Old 02-12-2011, 08:40 AM   #14
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
good suggestion about the nuts. here's measurements from mine:
Larry
fleetsidelarry is offline   Reply With Quote
Old 02-12-2011, 01:01 PM   #15
REDNOSE65
REDNOSE65's Avatar
Thanks Larry. That actually helps alot.
Clyde, If worse comes to worse, I'll get with you. Thanks alot!!!
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 02-12-2011, 01:19 PM   #16
Clyde65
Clyde65's Avatar
sure thing Red
Clyde65
Rebuild of Clyde
support our troops!
Old 02-15-2011, 12:48 PM   #17
REDNOSE65
REDNOSE65's Avatar
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 02-15-2011, 01:00 PM   #18
Clyde65
Clyde65's Avatar
Red you selling your truck?
Clyde65
Rebuild of Clyde
support our troops!
Old 02-16-2011, 10:19 AM   #19
REDNOSE65
REDNOSE65's Avatar
No sir.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 02-16-2011, 10:55 AM   #20
Clyde65
Clyde65's Avatar
wow, there is one just like yours on ebay and I was just thinking. that is really weird.
I cant find it now.
Clyde65
Rebuild of Clyde
support our troops!
Old 02-16-2011, 05:19 PM   #21
markeb01
Senior Enthusiast
markeb01's Avatar
Just a note, most of the trucks I've seen (including mine) with the factory nuts inside the door skin mount the mirror parallel to the style line on the door. As indicated in the schematic above by Aerotruk, they are level, not uphill in the front. Perhaps this changed over the years and the newer trucks are different. Just thought it was worth mentioning.
Old 02-17-2011, 10:26 AM   #22
REDNOSE65
REDNOSE65's Avatar
I cant find it now.
Hell Clyde I just want to get it on the streets!!!
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 02-17-2011, 10:42 AM   #23
BarnFind
That blue one with the red primer spots just sold on Ebay for 5500. I had been watching the listing. Sean
BarnFind is offline   Reply With Quote
Old 02-17-2011, 10:58 AM   #24
REDNOSE65
REDNOSE65's Avatar
Cool man. I like it. I just stole the pics because that's the angle I was trying to look at.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 02-17-2011, 11:01 AM   #25
REDNOSE65
REDNOSE65's Avatar
Thanks Mark, I noticed it too. That's why I posted that cl pic.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
