Old 02-10-2011, 11:46 PM   #1
TR65
TR65's Avatar
Conventional Tach on LS2
Hey guys,
I bought a cheap Sun Super Tach II to run on my LS2 swap using the tach wire from the ECM (E40). It would not move the needle.
I did some research on the web and several people said that you need to put a "pull-up resistor" in the circuit. The conventional tachs are looking for a 12 volt signal with the speed pulse riding on it. The ECM evidently just sends the speed pulse out on the tach wire at low voltage. So I put a 1000 ohm resistor from the tach power wire to the tach signal wire going to the ECM. So that pulls the tach signal up to 12 volts.
Works like a champ.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 02-11-2011, 06:32 AM   #2
67C10BUB
67C10BUB's Avatar
Re: Conventional Tach on LS2
Interesting...My Auto Meter tach had to be set for 4 cylinder mode to read properly.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 02-22-2011, 05:13 PM   #3
1tonjimmy
1tonjimmy's Avatar
Works like a dream thanks for the info.
1tonjimmy is offline   Reply With Quote
Old 02-22-2011, 06:11 PM   #4
67C10BUB
67C10BUB's Avatar
My tach reads correctly, but the needle vibrates an awful lot. Any ideas how to make it more stable?
67 5.3L Build
Old 02-22-2011, 06:36 PM   #5
Clyde65
Clyde65's Avatar
"Interesting...My Auto Meter tach had to be set for 4 cylinder mode to read properly.
__________________"
67, that is quite common on the LS motors.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-22-2011, 10:27 PM   #6
TR65
TR65's Avatar
67, Are you using the ECM tach wire? or do you have it wired up to one of the coils. The signal from the ECM should be very clean, and the tach should work on the 8 cylinder setting.
My tach is very stable, no noise at all.
TR
1965 C10 SWB Fleet
Two owner
Old 02-22-2011, 10:34 PM   #7
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I have mine (8.1L on a P59 ECM) to the ECM tach wire but also had to set it in 4 cyl mode otherwise it was reading 50%. My tach reads smooth and just as accurate as the GM Tech II scan tool.
DirtyLarry is offline   Reply With Quote
Old 02-22-2011, 10:49 PM   #8
TR65
TR65's Avatar
Dang DirtyLarry, Now you've got me wondering. I will have to check what setting I am using to be sure.
TR
1965 C10 SWB Fleet
Two owner
Old 02-22-2011, 10:55 PM   #9
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Ive got an autogauge (by autometer) and its set on 4cyl mode and it reads about 200 rpm more compared to HPtuners reading.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 02-23-2011, 12:04 AM   #10
DirtyLarry
DirtyLarry's Avatar
TR
I am even running the same Tach as you but an older version. I wonder if there is any difference between E40 and P50 ECM’s with respect to the Tach operation? Hmmm.
BTW….I love you truck! Man, your swap turned out great!
Old 02-23-2011, 06:42 AM   #11
67C10BUB
67C10BUB's Avatar
TR
Yes, I am using the tach wire, but my harness was done by Speartech, so I'm not sure which wire it is. If everyone else is getting a smooth signal, maybe I'll contact John and see if he has any ideas.
67 5.3L Build
Old 02-23-2011, 10:59 PM   #12
TR65
TR65's Avatar
DirtyLarry,
Thanks for the kind words. I love driving the truck with this swap.
Yep, I am using the 4 cyl setting!! Sorry, I read the switch wrong.
If I get a chance this weekend I will put a scope on that signal and see what it really looks like.
67,
Maybe the signal is just marginal and the gage is dropping "tops" making the needle erratic. Does your harness use a pullup resistor? Maybe that is the issue.
TR
1965 C10 SWB Fleet
Two owner
Old 02-24-2011, 06:39 AM   #13
67C10BUB
67C10BUB's Avatar
DirtyLarry,
67,
TR
I honestly have no idea how Speartech handles the tach output wiring. They do not include schematics with their harnesses. Perhaps I will forward your suggestion on to John (Speartech) and see what he thinks. Thanks for the input.
67 5.3L Build
Old 02-27-2011, 09:18 PM   #14
TR65
TR65's Avatar
I took a look at the tach signal that the ECM is putting out on the tach wire. This is for the E40 ECM so I don't know about other ECMs. The tach wire is used to drive the OE tach in the vehicle.
The ECM puts out a low voltage square wave that is two cycles or "tops" per engine revolution. That is the same as the number of times a 4 cylinder fires per revolution. So that is why we have to use the 4 cylinder setting to get the correct RPM. (V8 fires 4 times per rev.)
The first picture is the signal from the ECM. So the (-1.5 V) voltage is probably too low to fire the traditional tachs that are looking for around 12 volts.
The second picture is the signal with the pullup resistor installed. So now the voltage is up to 10V at the high. So the tach wroks fine.
The engine was idling at about 680 RPM or 11.3 rev per second. The frequency of the signal is twice that, around 22 cycles per second.
TR
1965 C10 SWB Fleet
Two owner
Old 02-28-2011, 05:09 PM   #15
67C10BUB
67C10BUB's Avatar
Wow, that is some great info. Thanks for posting. I was just curious how you did this. Was it done with an oscilloscope?
67 5.3L Build
Old 02-28-2011, 11:25 PM   #16
TR65
TR65's Avatar
Thanks 67.
I read up on your swap. Very nice work. Very nice truck.
Let me know if you get your cruise control to work.
I took the data on the tach line with a cheap USB data aquisition unit.
http://www.mccdaq.com/usb-data-acqui...08-Series.aspx
I have the 1208FS. It has an oscilloscope mode and a data logger mode. Very handy.
TR
1965 C10 SWB Fleet
Two owner
Old 03-01-2011, 06:50 AM   #17
67C10BUB
67C10BUB's Avatar
Thanks 67.
TR
Very interesting stuff. A little over my head, but interesting. You are obviously a very valuable member of this LSX swap community with knowledge like that.
67 5.3L Build
Old 03-04-2011, 08:06 PM   #18
diyernh
TR
TR65,
I believe the 1.4 V signal was not from the ECM. The MCCDAQ USB1208FS has a low level output signal at 1.4V. Essentially you were using the DAQ as a pullup for the ECM Hall Effect Signal.
I made the same mistake, thinking my O2 sensor was outputting 1.4V. 100$ sensor later, I have confirmation from MCC that Single Ended readings on the DAQ output a 1.4V signal. This can be confirmed by reading the pins directly on the DAQ with a DMM. Mine reads 1.4VDC, 11 micro Amps.
I found this stray voltage does not happen when you use differential measurements.
Typically Hall Effect sensors ground when the magnet is lined up. If you aren't getting a reading, check the power being applied (pullup circuit). There may be a blown fuse or loose connection
Carl
diyernh is offline   Reply With Quote
Old 03-06-2011, 12:31 AM   #19
TR65
TR65's Avatar
Originally Posted by diyernh View Post
TR65,
Carl
Carl,
1. I am not reading the sensors. I am reading the tach signal output from the ECM. Neither of the engine rotation sensors would be suitable for a tach. The crank position sensor is 24 tops per rev and the different tooth lengths give a non constant frequency. The cam position sensor is one cycle per two revs.
2. I was using a single end connection. I went back and measured using a differential setup as you suggested. There is then no signal recorded from the ECM.
So, The ECM is grounding the tach signal line at a frequency of 2 times per engine revolution. So to get any signal at all the tach has to supply a voltage on the signal line. With the pullup resistor you then get a 0-12 volt square wave that the tach likes. (As in the graph above just shifted up)
Thanks for the tip.
TR
PS
I found this recording of the two engine speed sensors.
http://www.ls1tech.com/forums/pcm-di...going-bad.html
1965 C10 SWB Fleet
Two owner
Old 03-27-2011, 01:11 PM   #20
Rokcrln
Rokcrln's Avatar
Hey guys,
Works like a champ.
TR
TR,
I just did an 05 5.3L swap and I am using the stock style 70 tach and it does not read at all from the ECM's tach wire. So if I install the same 1000 ohm resistor like you did it should all work our fine? Can I just put the resistor right at the back of the gauge under the spade connections? Is their a power and a signal side of the resistor?
Thanks for any further help on this.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-27-2011, 03:25 PM   #21
Thealien
Thealien's Avatar
Originally Posted by Rokcrln View Post
TR,
Kevin
LFD Inc.
I am using the factory Tach in my 1972 Jimmy with my 5.3 swap. I needed the pull up resistor and did install it right between the wires at the connector that plugs into my Tach. My tuner had to change the output in EFI live (think the same can be done in HP tuners) as our Tachs don't have a 4/8 cylinder switch. Mine is very close to the readings in EFI live and an aeroforce guage I use.
Old 03-27-2011, 04:53 PM   #22
Rokcrln
Rokcrln's Avatar
Is this a radio shack resister or? Would you have a part number or description so I can tell them what I am needing? Now I do not have a program for my ECU as I had Street and performance do the flash, will a hand held programer do anything for this?
Kevin
LFD Inc.
Old 03-27-2011, 10:32 PM   #23
TR65
TR65's Avatar
Rokcrln,
The current draw is very low so a common 1/4 watt 1000 ohm resistor from Radio Shack will work fine. Should be less than $1.
There is no + or - to the resistor, mount it either way. It just needs to go across the power and signal wires. Shouldn't matter where.
Like Thealien said. With a stock tach from a V8 you will probably need to change the tach calibration with tuner software.
TR
1965 C10 SWB Fleet
Two owner
Old 01-03-2013, 11:43 PM   #24
Critter
Future TOTM Winner
Critter's Avatar
This FAQ has been up for a while, but for the sake of information for the masses I felt the need to add to it.
With EFI Live I simply tell the ECM to "pull up" the output of the factory harness wire. Also I correct the pulse calculation so that the wire puts out the correct signal for a standard 8 cyl tach. The reason that people are having a variety of things happen here is most likely due to how the person that flashed the computer set up (or didn't set up) the tach signal.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-08-2013, 01:23 AM   #25
1972K20
1972K20's Avatar
Critter, when the computer is flashed, who would you recommend to have it done correctly?
1972K20 is offline   Reply With Quote
ls2, tach wire, tachometer
