Old 07-07-2003, 04:25 PM   #1
boataddict26
Question 350 Trans. Question..
I have a short shaft the is rebuilt and works fine. I also have a long shaft that is no good at all. Which is better to have, a short or long? And why. Could I switch the tail shafts?
1978 Chevy C10 Currently under resto.
350 Getting face lift. .060, JEpistons, Modify heads. More will come with money.
boataddict26 is offline   Reply With Quote
Old 07-07-2003, 06:56 PM   #2
boataddict26
I have the long drive shaft for short tail shaft tranny. I was just wondering if there was some performance difference. Thanks for the info.
Old 07-07-2003, 11:43 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Generally the short shafts are a little better for performance w/ short driveshafts. I don't think there is a lot of difference between the two but I would go with the short shaft for strength also. Short/wides trucks have this little advantage because of less distance from the engine to the differential. I believe this to give them a small edge on long beds performance wise.
As far as gear ratios they should be the same.
If you have a lot of power and would like an O/D and cost isn't a factor there are ways around that. This is the setup I would like to have running. Hughes HD TH-400 with the 2.75 1st gear - 2200 stall - Transgo shift kit - HD trans cooler - gear vender over/under drive system - 3.42 gears or better (higher numerically) - Eaton Posi - any size tire you want to run.
Of course this is all suited to my engine. might be a little over kill but this to me is the best I can get for my setup.
MylilBowTie is offline   Reply With Quote
Old 07-07-2003, 11:48 PM   #4
boataddict26
That sounds AWESOME!! But expensive. If that was all I had to save for I would get a performace set up like that. For now I will have to stick with the 350 and B&M rebuild kit.
