Old 04-08-2011, 02:42 PM   #1
bigwil86
67 GMC 305 V6 swap to a SBC 305
Hello all, Im new to the site but none the less love these old trucks and have since before i could drive.
Yesterday I made a purchase on what i thought was a GREAT deal on a 67 GMC C15/1500, swb, fleetside pickup truck with the 305v6 and 3 speed on the column. Not until i start thinking about doing a sbc swap that i realize i maybe in a little bit of a pickle. Im at a total lose on the swap and no clue where to begin.
Would it be possible to cut the frame off of 73-87 frame right in front of the fire wall and have it measured up and weld into place on mine after the removal of the front section of my 67 frame. The 73-87 frame would allow for disc brakes, spindles, sbc motor mounts and eventually allow me to install airride suspension a bit easier, or would it just be simpler to swap the crossmembers?
Any help would be greatly appreciated, Thank you!!! Wil
bigwil86 is offline   Reply With Quote
Old 04-08-2011, 04:14 PM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: 67 GMC 305 V6 swap to a SBC 305
You can put 71-72 Disc brake set up on your rig much easier. There are plenty of easy mods to do what you want without major work.
Pull the engine and trans.....I dont know about the mounts for the V-6 but the V8 will be a direct bolt in with the correct v8 mounts.
Its a pretty basic engine swap.
You can then add power steering and power brakes. With a 67 there will be a little difference in the power steering set up needs.
I would recomend finding a 72 2x4 donor truck...you will then be 5 lug and your wheel options will be MUCh better
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 04-08-2011, 04:34 PM   #3
bigwil86
The motor itself is in amazing condition, no pings, peeks, knocks, or leaks but I would still rather swap in something a little more conventional. Any advice about the x-member?
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 04-08-2011, 04:48 PM   #4
72freak
72freak's Avatar
What do you need to know about the x-member? Are you talking about the trans x-member? If you are staying with a 3 speed it should not have to be touched. If you are talking about under the engine that all stays the same also....you just swap the spindles and brke stuff.
Old 04-08-2011, 04:50 PM   #5
bigwil86
Did GMC offer a v8 in there c15 truck in 67. Thought it wasn't until 68 they offer a v8.
Old 04-08-2011, 04:53 PM   #6
bigwil86
No PM / email sales...thanks for your support
Old 04-08-2011, 04:54 PM   #7
72freak
72freak's Avatar
Yes.....327 was one of them
Old 04-08-2011, 05:41 PM   #8
bigwil86
The best I can tell according to autozone, advance, oriellys. The parts search only shows 3 motor options all being V6s. 68 offers all kinds of v8 options. So the only thing I can do is take it out and figure my options from there. The V6 mounts are welded in.
Old 04-08-2011, 08:02 PM   #9
72freak
72freak's Avatar
Here is the SPID from one of my my 1967's that clearly states 327 and Im sure others will chime in shortly. I believe my 67 C-30 came with a 283. Im sure you know that those stores are not known for their vintage, classic and antique automobile knowledge...or much else!!!
As far as the motor mounts being welded in...that must have been done by a previous owner....get out the grinder. You can get a set of V-8 engine stands her on the board or on Craigs list for $40 all day long and they bolt right in. A fresh set of motor mounts from the era, line it up with the tranny, set it in ....and a day later you are back on the road!
http://67-72chevytrucks.com/vboard/s...d.php?t=438214
Post us some pictures of your project.
Old 04-08-2011, 11:51 PM   #10
Bob B.
283's and 327's were an option in GMC pickups starting in May '67, late in the model year. The swap is pretty easy with the right parts. You need small block V-8 mounts and towers, along with a V-8 bellhousing if you have a manual transmission. If you have an automatic, your transmission will work with the right flywheel. GMC V-6's used Chevy automatics with adapter plates. Here is information on the GMC V-6's. Read up on them, you might decide to keep it!
http://www.6066gmcguy.org/
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 04-09-2011, 01:37 AM   #11
bigwil86
Thanks for the all the help, I'm going to pull that motor as soon as I have time. My truck is probably the second half of 67 cause its the round body style like 68-72 instead of the 60-66 style.
Old 04-09-2011, 06:49 AM   #12
72freak
72freak's Avatar
Thanks for the all the help, I'm going to pull that motor as soon as I have time. The only reason I won't keep it is because of the parts availability. My truck is probably the second half of 67 cause its the round body style like 68-72 instead of the 60-66 style.
Both the 283 and 327 were available for the 67 according tio the adversising documents which makes sence because both were available in the mid 60's also.
Old 04-09-2011, 08:24 AM   #13
bigwil86
Old 04-11-2011, 02:37 PM   #14
bigwil86
i got my truck home yesterday and took a look at the motor mounts and bracket......also just want to say thanks for all the help and advice......we figured out a very easy way to just set the 305 v8 right in place with very minor modification!!!! thanks again...
Big Wil
Old 04-12-2011, 08:39 AM   #15
72freak
72freak's Avatar
Now we need to see pictures!!! Try to get some of these welded in engine stands/motor mounts!!
Old 04-12-2011, 10:30 AM   #16
bigwil86
Apparently I was wrong bout the engine stands cause mine has the bolts in frame horns but that is a forum on here where a gentleman had the welded in mounts and had to cut and move them for the sbc swap. I'll get up some pics as soon as I get to my comp. I been using the site on my phone.
Big Wil
Old 04-13-2011, 03:02 AM   #17
Erik V
reminds me of my old 72 2wd GMC. 250-6/3tree. I hated how gutless it was, and built a modest 305 out of my mom's old 78 Impala we retired. TH350 swap while I was at it, leaving the 4.11 rearend for a while, boy was that truck quick to ~80, but thats as fast as it'd go.
Done properly you'd never be able to tell from a hood pop. The only tell tale sign in my swap was bolts instead of rivets on the trans crossmember. But I had a parts truck that donated everything to do it factory style.
Those 305's are good basic engines, with headers, intake/carb on stock pistons/rods/heads, my pickup would run circles around Dad's 69 2wd Chevy with a 350/th350. Even when I went to a 3.07 rearend to his 3.73. So keep an eye on the rearend, I dont know what the 305 V6 came with, but the 305 V8 wont like a 4.11 unless you want to snap necks and top out around 80.
Erik
Erik V is offline   Reply With Quote
Old 04-13-2011, 08:09 AM   #18
70cst
70cst's Avatar
Ok all...
Lets keep the For Sale, Want To Buy, and offers off this thread. Thanks.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-13-2011, 08:48 AM   #19
bigwil86
I apologize about that. Still kinda new to the thread.
Big Wil
Old 04-13-2011, 08:54 AM   #20
cam.man67
cam.man67's Avatar
So, why do you want to get rid of the 305v6? Great motors.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 04-13-2011, 09:04 AM   #21
bigwil86
Im sure the are great motors and extremely torquey but the parts avalibilty is getting almost none exhistint and apparently they are kinda a pain to work on plus as heavy as a 10 ton tank. The build specs on the SBC 305 Im putting together will allow me too produce about 375 hp and still get approximately 22 mpg. and at todays prices that means something. lol. I'll be running a mildly built 305 SBC, 700R4 Trans, 4.10 Gear.
Big Wil
Old 04-13-2011, 10:10 AM   #22
Warrens69GMC
Warrens69GMC's Avatar
..... SBC 305 Im putting together will allow me too produce about 375 hp and still get approximately 22 mpg. and at todays prices that means something. lol. I'll be running a mildly built 305 SBC, 700R4 Trans, 4.10 Gear.
Curious on the build of the 305 - 375hp and 22mpg isn't easy in these trucks, and a 375hp 305 isn't mild...
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 04-13-2011, 10:38 AM   #23
406 Q-ship
406 Q-ship's Avatar
........The build specs on the SBC 305 Im putting together will allow me too produce about 375 hp and still get approximately 22 mpg. and at todays prices that means something. lol. I'll be running a mildly built 305 SBC, 700R4 Trans, 4.10 Gear.
A 350 would be the better choice and will get the gas mileage if built right. 4.10's will not get you 22 MPG even with the 700R4, 3.42 is the steepest gear that might be possible to achieve 22 MPG. That kind of mileage in a truck would be impressive unless you switch to one of the later model LS series of engines, the older SBC Vortecs will get is to but a bit more of a struggle.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 04-13-2011, 10:45 AM   #24
N2TRUX
Happy to be here
N2TRUX's Avatar
As you have discovered, its not necessary to swap clips to gain V8 mounts and disc brakes. You can look for 71-72 brake system but they aren't as readily available as the 73-87's. The later system is cheaper for replacement parts too.
Take a look here "Drum to Disc" conversions 67-70for a great guide on the subject.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-13-2011, 11:18 AM   #25
bigwil86
Yea, I'm in the process of trying to find a 71-72 c10 donor truck now. But as for the 305 v8 I'm building its a 305 with 4 bolt mail splade caps for added durability, speedpro/king bearings, 305 X-beam rods with dome pistions, 200cc ACR aluminum heads with 202/160 valves, 1.6 aluminium roller rockers, screw in head & rocker arm studs with polylocks, Jegs 468/488 lift cam with 110 lobe separation, dual plan weiand highrise intake with 650 cfm holley. I run this exact same set up a 83 S10, I know the GMC is a bit heavier so the gas mileage may fall off a bit but after the motor is tuned the numbers are good.
Big Wil
305 v6, c15, gmc, sbc swap
