#1426 |
Grandpa in the rustmobile...
Re: "Rice Rocket'
Starts better the starter crapped out like 2 days after the show I guess..
Starts a little better, but still takes awhile to start sometimes (wirrrrrrrrrrrrrrrrrrrrrrrrrr vrroooom). Sounds better while starting and seems like the new starter is stronger? Been gone for the past few days with the gf and some friends riding atvs in east TN pictures and some good wreck videos later
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#1427 |
Truck and auto performance nut
Re: "Rice Rocket'
so whats your initial timing at?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#1428 |
Re: "Rice Rocket'
I'll try'n check it sometime, im exhausted from the past few days..uh going home soon for a nap..
#1429 |
Re: "Rice Rocket'
Around 18* BTDC with vac. adv plugged at idle
Like it sits is how it runs best (starts and has power) I can spin the dizzy so it runs/has more power, but wont start. Or I can make it start good but wont run good.. Its got the stock springs back in it. I talked to the speed/machine shop they said they usually delete the vac. advance or something so it runs better? They said for $20 they'll do it, seemed sorta wierd. I wanna leave that alone, the guy that built/did the machien work I trust, but he is so far (about 1 hr) ive quit driving the blue truck back and forth to school (33 miles with gas $4.05 93 octane). I dunno..lol
#1430 |
Re: "Rice Rocket'
What should I do?...bring it down to around 8*
I can borrow a adj. timing light to get my total timing if needed...may borrow a vac guage also..
#1431 |
Re: "Rice Rocket'
disconnect and plug the vacuum advance and set your base timing around 8* or so. Then plug the vacuum advance back in and see what you got at idle. Can you check for total* advance? Is you vac adv. adjustable?
oh...and you'll get varying opinions on the subject, here's mine: racing = no vacuum advance needed street = vacuum advance for a more efficient, cooling running motor
#1432 |
Re: "Rice Rocket'
vacumn can isnt adjustable
I can borrow a gun thats adjustable.. I'll set my base @ 8* and report back on how it starts/runs I wanna run the vac. adv.
#1433 |
Re: "Rice Rocket'
I did install some better plug wires (old ones were burnt in spots etc etc)
I think it runs smoother (but could be my imagination) still takes forever to 'hit' sometimes though..timing I guess. Maybe I can get it.. And I got my hitch finished bolting in, now I need to get some pretty paint on it, any ideas for colors?
#1434 |
Re: "Rice Rocket'
loving your build dude! your a lot further then i am. although your going after more looks while im going after more drivetrain first. i hope to do some rattle can'in this summer!
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear! 1969 C30 Open Road Motorhome 350/th400 1972 K10 350/350/205 Daily Driver -SOLD |
#1435 |
Re: "Rice Rocket'
I went over my suspension etc too
rebuilt frontend with discs swaybar trailing arm bushings etc wish I didnt skimp on gaskets for my motor, it would be nice and shiny still lol
#1436 |
Re: "Rice Rocket'
haha, i know how that goes. that mys 350! all i id to suspension is trailing arm mounts on my axle. just ordered new axle seals and planning on shocks and suspension bushings this summer as well
#1437 |
Re: "Rice Rocket'
cool! you need to make a build thread!! i looked but didnt find one..
#1438 |
Re: "Rice Rocket'
alright, sweet. ive wanted to make one so ill start soon!
#1439 |
Re: "Rice Rocket'
way cool pics john! nice work!
#1440 |
Re: "Rice Rocket'
Set initial timing at 10* btdc letting it sit aminute, the PO of the danged fan shroud trimmed it, well the fan caught my pinky at 800rpm hurt like heck!!! carnage picture later i think im putting my stock springs back ima be doin some hauling etc and the jeep springs are stupid because theyere so thin
i lost my cell phone too i think it fell out the floor holes...dang 200 doller phone please excuse my typing my pinky is uselss and I dont want to try to re learn its throbbing!!!! safety first uhh I had to adv it to get the 8* if that makes a difference Oh, and im going by the stock timing slot on the balancer...(heard you need to verify this I never did get it)
#1441 |
Re: "Rice Rocket'
I think the balancer mark can be off a little...but should be in the ballpark?
So is it 8* or 10*? and does it start easier?
#1442 |
Re: "Rice Rocket'
It starts the same, Sometimes it starts right up and sometimes it starts like its not getting gas you have to pimp the pedel etc..?
#1443 |
Re: "Rice Rocket'
What should it be set at (initial)
Ill double check.. Should I re set the valves (0 lash)? Brad penn oil change/wix filter comming soon, along with 1 piece oil pan gasket and new rear main seal..
#1444 |
Re: "Rice Rocket'
uh......forgot what your combo is, its not in your sig
#1445 |
VA72C10
![]() Join Date: Mar 2008
Re: "Rice Rocket'
Is the harder starting after it's been sitting or just random?
I've had a lot of older vehicles and always pump the pedal a couple times when starting unless I just cut it off....
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#1446 |
Re: "Rice Rocket'
I can cut it off and sometimes ill have to pump the pedel sometimes i wont
Its just annoying and embarrassing, wwwwwwwwwwwwwwwwwwwwwwwiiiiiiiiiiiiiiiiiiiiiiiiiiiiiirrrrrrrrrrrrrrrrrrrrrrrrrrrr VROOOM ![]() Put my stock rear springs back in, i like the low look but I couldnt haul anything so it was worthless to have a truck bed,and on these crummy side roads it bottomed out in potholes 355 summit 'vortec' heads 279 thumper cam I have to run 93 gas because the comp. ratio pretty much stock everything else (kb pistons balanced bottom end) rpm edelbrock intake eddy 600 1406 carberator
#1447 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: "Rice Rocket'
I want someone to finally admit that these springs just don't work. Ha.
#1448 |
Re: "Rice Rocket'
lol lolife
they work if you never haul anything, and have really really nice roads I guess im saving my nickels for some heavy duty 4" dropped springs lol
#1449 |
Re: "Rice Rocket'
If you can't haul anything,... "they don't work".
I think Hart Rod had some used 4" springs,...
#1450 |
![]() Join Date: Apr 2009
Re: "Rice Rocket'
they do work...... for looks
