Cargo light switch location?
About sums it up. Can someone describe and post a pic of where the cargo light switch is located from the factory? Thanks all....
Resident Curmudgeon
![]() Join Date: Dec 1999
Adam,
Centered directly underneath cab interior light. I don't have exact dimensions but it is centered below. You need to cut a rectangle hole for the switch to set into. Wish I had a pic...
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Finish the'71..or bust!
Heres a pic from my '71
I hope this helps:
SLS has attached this image: ![]() The top of the switch butts up against the raised ridge at the bottom of the courtesy light hole....and all is centered in cab. My switch is a tad crooked...so I'm not sure whether this one was installed by the factory...or some jackleg at the dealer. Just another thing on my mile-long list of stuff to fix...LOL. ![]() Sorry for the 'dirty' pic...but it is one of the cleanest areas on this ol' truck. ![]() Last edited by SLS; 07-21-2003 at 11:49 AM. |
Wow.....ask and you shall receive. Thanks for the info and pic guys. Thanks again Jeff.
its all about the +6 inches
Mine was a little off center, and I know it was original.
