Old 05-31-2011, 07:59 PM   #1
fredico
Need some advice here
I have a 71 K5 Blazer that I would like to drive again.One of the many issues needing attention is the drivers side front spring hanger bolt hole being wallowed out. I've been looking for a replacement hanger but not having any success. Can someone lead me to a possible source of supply? If I can't find one soon I thought about drilling out the rivets, removing the hanger, filling the wallowed out bolt hole with weld and drilling a new bolt hole. never done it but desire can cause solutions to happen. What would be some other possible remedies? thanks.
fredico is offline   Reply With Quote
Old 05-31-2011, 08:07 PM   #2
cleszkie
cleszkie's Avatar
Re: Need some advice here
I had the same issue. I just left the hanger on the truck, layed down a weld bead on the wallowed out part, and a ran a drill bit through it to round out the hole again. Works great, and only took like 30 minutes.
cleszkie is offline   Reply With Quote
Old 06-01-2011, 01:47 PM   #3
fredico
Thanks Cleszkie. That is the fix I will go with. thanks again.
Old 06-26-2011, 10:24 AM   #4
fredico
Wound up with a variation of the proposed fix. Took #8 flat washers and welded them to the outside of the hanger/perch because of a nagging thought whether the weld material would last. I now feel confident that the new bolts won't wear out the hanger/perch.
Old 06-27-2011, 03:54 AM   #5
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
do both. it acts as a doubler and you wont have to worry about it again
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
