Old 06-12-2011, 12:29 AM   #1
69pickupnyc
rear disk brakes
I have a 69 c10 with a 1971 c10 rear installed in my truck to convert to 5 lug. I would lie to convert to disk brakes does anyone have a suggestion on what to use and where to buy? I would like to buy a setup that will take stock replacement parts from a local parts store if I have a repair problem.: :
69pickupnyc is offline   Reply With Quote
Old 06-12-2011, 12:39 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: rear disk brakes
Here you go,...
http://67-72chevytrucks.com/vboard/s...d.php?t=398352
Keith
Convert to disc brakes.
Old 06-12-2011, 10:07 PM   #3
69pickupnyc
does astro van rotors from 1992-02 fit on the rear axle from my 71 rear wihout modification. the inside hole is 3" and the hub with the lugs
is 6 1/2" ?
Old 06-12-2011, 10:17 PM   #4
lolife99
lolife99's Avatar
Originally Posted by 69pickupnyc View Post
does astro van rotors from 1992-02 fit on the rear axle from my 71 rear without modification. the inside hole is 3" and the hub with the lugs
is 6 1/2" ?
I believe so.
You might contact Captainfab with your questions.
Keith
