Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-09-2011, 01:31 PM   #26
1971ls1longbed
1971ls1longbed's Avatar
Re: My powerplant is here!!!!
Is this motor going on a reputable Superflow dyno,, or are we just 'guessing' ?
Yes sir it will put on a superflow dyno at Fonse Performance in Erial NJ
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted
1997 C3500 DRW Ext cab. 454, 4L80E daily driver
1971ls1longbed is offline   Reply With Quote
Old 07-09-2011, 03:26 PM   #27
Marv D
Registered Truck Offender
Marv D's Avatar
OK then,, I'm going to be the spoiler that makes all you bbc guys
If this were a sbc,, with a set of home ported factory heads (assuming or they would have a flow sheet I would think) with a pretty mild roller for the cubic inches, only 9.25:1 compression,,,,,, I'd not expect it to break 1HP per cube.
My guess is ya all are being a bit optimistic. I'm officially logging in at 430HP at around 6400.... and I HOPE you prove me wrong!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-09-2011, 03:40 PM   #28
Marv D
Marv D's Avatar
And now that ya all are forming a lynch mob... I also think it's going to make 480+ pounds of torque is a DRIVABLE rpm range that is going to make it an ANIMAL on the street.
I just think it's going to be a bit air hungry up high to make the big HP numbers some of you are thinking. But again,, I hope i'm wrong.
Old 07-09-2011, 05:48 PM   #29
1971ls1longbed
No lynch mob forming but i am basing my build off of a Wheeler performance build which has a milder cam and 8.75:1 compression and it makes 480hp I called them and that's the cam they suggested and about 525 HP and 560 tq
Old 07-09-2011, 07:01 PM   #30
Marv D
Marv D's Avatar
When you headed to the dyno? I'm really interested to see what she does. I don't know squat about big blocks other than to know they always surprise me.
Old 07-09-2011, 07:33 PM   #31
Blue Rat
520 HP an 540 TQ @ 5600
Blue Rat is offline   Reply With Quote
Old 07-09-2011, 08:21 PM   #32
1971ls1longbed
I'm headed to the dyno in about a month or two. The shop owner is a very good friend of mine and I still need a few more parts. This is my first dance with a big block so I'm new at this too but so far I'm not disappointed. I'm just shopping smart and saving money where I can. I am anxious to hear this thing fired up and see what it does.
Old 07-10-2011, 04:35 PM   #33
1971ls1longbed
Here is the link my engine is loosly based on as a reference point
http://www.wheelerpowerproducts.com/...eet-crate.aspx
Old 07-10-2011, 05:24 PM   #34
Super73
Super73's Avatar
Ok, here is what I have come up with...
454 .030" over with a lower friction piston design
Ported 049 heads since I don't have flow numbers for you ported 781's
Hyd 236/242 .521/.540 (I am using a 108 intake center line and 108 lobe sepperation. If you give me the actual ICL and LSA I can tell you more accurately)
1.7 rockers
750 non-vacum carb
RPM Air Gap
1 7/8 headers (guessed length to be 30", again if you measure them, I will give you more accurate info)
Low windage oil pan design
562ftlbs @ 4500 and 557hp@5750.. This is using an electric fan, electric waterpump and no accessories.
Now with a flex fan, mechanical water pump and powersteering it moves to 546ftls @ 4500 and 534hp @ 5750
Same fan, water pump and power steering, but production windage and a standard friction piston design, 531ftlbs @ 4500 and 513hp @ 5,750..
Does that help?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-10-2011, 06:07 PM   #35
1971ls1longbed
1.7 rockers
750 non-vacum carb
RPM Air Gap
Does that help?
LOL wow yea that helps and the headers r 2" primaries and 35 inches long and the lsa is 110 and the icl is 106
Old 07-10-2011, 06:14 PM   #36
1971ls1longbed
i will be using a mechanical water pump, electric fans, standard friction pistons, and powersteering
Old 07-10-2011, 07:40 PM   #37
Super73
Super73's Avatar
Unfortunately I can not sellect a mechanical water pump with electric fan. So Here is the set up..
454 .030" over
Standard friction pistons and factory type windage
The ported 049 heads
Hyd 236/242 .521/.540 106icl 110lsa
1.7 rockers
750 non-vacum carb
RPM Air Gap
2" headers at 35" length
91 octane
Mechanical fan, mechanical water pump, powersteering
TQ 535ftlbs @ 4250-4,500 and 513hp @ 5500 (511hp @ 5750)
Same combo above but with electric fan, electric water pump and no accessories:
550ftlbs @ 4500 and 534hp from 5500-5750
Old 07-11-2011, 09:52 PM   #38
Marv D
Marv D's Avatar
looks like I should have loaded it in EApro before opening my mouth and demonstrating my small(block) thinking . That OK, it ain't over till the fat lady songs her song on that dyno
Old 07-12-2011, 08:44 PM   #39
1971ls1longbed
i used to be a small block guy but once the BBC bug bit it was all over for me
Old 07-12-2011, 10:09 PM   #40
Super73
Super73's Avatar
I'm not taking anything away from the guys running big blocks, and expecially ones that move. But, small blocks are nothing to look down upon either. I don't want to get in to ricer math, but my SBC's sure have competed well for their size against the bigger cubed motors.
Pump gas 347ci running 11.47 @ 118mph is nothing to sneeze at in one of these trucks. Heck, the majority of the big blocks on this sight don't run that with 100+ more cubic inches. Not saying they can't, DJ, Regan, BigJim and others are prime examples of what big blocks can do. Yes I know my 347 was more of a radical build, but I would expect that a somewhat tame big block should run that all day long.
Now as far as longevity.. My old motor ran strong for 5 years, had 75+ passes at the track, countless dyno pulls, 15,000 miles on it (and some of them were not easy miles). Today that motor is being run in a sand drag truck with a 200 hit. With no changes to it (except a carburated intake) he has placed 1st and 2nd in the two events he has run along side with some radical big blocks and small blocks. I expect that motor to go for a long time with little to no maintainence.
The new motor, for what it is (pump gas hyd roller), I think it will again be a competitor.
Old 07-12-2011, 10:15 PM   #41
1971ls1longbed
oh believe me im not knocking SBC's at all im a huge fan of big inch sb's and a bigger fan of the LS but for me its the raw torque of a BBC that i love. and i have a lot of respect for the combo you have
Old 07-12-2011, 10:19 PM   #42
djracer
djracer's Avatar
The Ls stuff is worlds ahead of the older Small Blocks. I wouldn't be scared to build a nice motor on the Ls platform. If my son decides to make his truck into his daily driver It will probably get a warmed over 6.0 truck motor.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-13-2011, 04:22 PM   #43
1971ls1longbed
your absolutely right they make great power on the cheap
