Old 07-11-2011, 12:54 PM   #1
frankenstein69
Driveshaft question
I am putting a turbi 400 tranny in my 69 chevy truck and the 2 piece Driveshaft is 5 inches too long. Could I use a Driveshaft from a 76 chevy longbed instead. that is the year of the tranny. Thanks in advance
frankenstein69 is offline   Reply With Quote
Old 07-11-2011, 01:41 PM   #2
El Campo
El Campo's Avatar
Re: Driveshaft question
Is the 69 a LWB also? and was the tranny in the 76 a 400? The Turbo 350 has a different yoke so even if it is right length you would have to change that. Otherwise you should have no problems IF its same length. You know that you have to pull yoke out one inch from seated (against the case of the transmission) to measure it, right? Is the 76 a one piece or two piece? You can always to to a one piece shaft also or cut the one you have. Most drivetrain shops (here in Houston anyways) will cut one down for about a hundred bucks
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 07-11-2011, 01:54 PM   #3
brad_man_72
the boat guy
brad_man_72's Avatar
it seems like alot less hassle to have your diveshaft shortened and ballaned with the correct yoke. Maybe have them check out/replace your ujoints and carrier bearing since you're there.
you know instead of tracking down a junkyard driveshaft hope it's the right length, hope the wearing parts are in good shape, hope it hasn't been bent, hoping it hasn't been worked on since it was ballanced last.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 07-11-2011, 03:47 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there's a lot of variables here, i would tend to lean to a no on the answer... but you can always run a tape measure and take a look at carrier bearing mounting type.
