07-20-2011, 06:31 PM | #151 | |
Re: slamburban
You've have done some nice work, and we did do some of the samethings but i might have went a little over board on some.. Not sure you can see or not but i mounted the air tanks on the outside of the frame rails on ours and put a pump in front of each one.. saved a little on running lines every where and gave a little more room in the middle.. You did a nice job with the rear end set up even though you had to raise the floor. you'll have to let us know how it rides.. What are you going to do for interior?? Parkwood |
07-20-2011, 11:49 PM | #152 |
Re: slamburban
ya,thats a really good way to run the air tanks. i used airbagit.com and i wish i would have done air ride tech.it looks like a better set up. as far as the interior. it didnt come with any seats. i am using 4 1972 chevy blazer buckets and two mid 2000s f150 center consoles. as far as the inside panels.it used to be a shrinners bus years ago and had two side mounted fold down benches which damaged both sides really bad. so the plan is to paint the upper half above the factory interior panels blue and vinyle the lower half.and put in a foam backed headliner like new cars have,but thats still up in the air.
07-21-2011, 12:00 AM | #153 |
SAVING ONE TRUCK AT A TIME
Re: slamburban
hey fred your burbs lookin killer.you and charlie are kickin a**.i have my third row seat that we are not going to use if your interested.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
07-21-2011, 12:59 AM | #154 |
Re: slamburban
chizzler, how yours coming along. i should have mine hopefully on the road by the end of the month.
07-21-2011, 01:10 AM | #155 |
Re: slamburban
here are some pics of the seats and rear center consol/buddy seat. they are really dirty from sitting in my garage but i had them redone last year.
07-21-2011, 01:20 AM | #156 | |
Re: slamburban
07-21-2011, 10:54 PM | #157 |
Re: slamburban
charlie got the drivers back inner wheel well almost all welded in.he just needs to do some finish welding. then copy it on the passanger side.after some grinding and painting, it will bolt to the floor like it was factory. he cut and sectioned it so i could get my seats to go back about 8 inches for more foot room.
07-21-2011, 11:46 PM | #158 |
Re: slamburban
Looks real good....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-28-2011, 01:33 AM | #159 |
Re: slamburban
got the inside,dash,jams and the doors painted
07-28-2011, 01:45 AM | #160 |
Re: slamburban
more pics
07-28-2011, 01:49 AM | #161 |
Re: slamburban
Fred, that's looking good.. what car is that blue off of or is it a special mix..??
07-28-2011, 01:57 AM | #162 |
Master Procrastinator
Re: slamburban
looking great as always, are you planning on running the classic visor on the windshield?
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
07-28-2011, 10:53 PM | #163 |
Re: slamburban
steve the glass worker got the glass in today. now i can put in the visor,but i bought it from somewhere back east and it got caught in a hail storm. so i got some body work to do on it first.the blue color is something i picked out of a catalog.
08-02-2011, 10:48 PM | #164 |
Re: slamburban
got the front seats mocked up. i used a center consol seat out of a 2000 dodge dakota and to let passangers in the rear i got a fold forward seat out of the second row of a 1994 chevy lumina van.all i have to do now is drill holes and run u bolt in the floor for the van seat.then redo the seats and consol to match the rest.
08-02-2011, 11:14 PM | #165 |
Re: slamburban
got the steering column and steering shaft in. i used a chrome exhaust tip to cover up the ugle column end that stick out throught the firewall.
08-03-2011, 12:15 AM | #166 |
Re: slamburban
it goes to get rewired on the 15th.i got to start getting real busy. i have a ton of small things to do.
08-03-2011, 12:34 AM | #167 |
VA72C10
Re: slamburban
nice progress!!! I really like the exhaust tip idea!!!
Looking for a 67-72 swb or blazer project in or around VA. |
08-03-2011, 01:34 AM | #168 |
Re: slamburban
Moving right along and looking good....Jim
08-12-2011, 12:18 AM | #169 |
Re: slamburban
installed the grant telescopic tilt wheel adapter. descided to use the center lower part of the dash for two cigerette lighter ports and three push pull switches for my fog lights, halo lights and city lights. installed the fuse panel in the glove box.also had jute glued on the floor. tomorrow the carpet and seats go in and we set it on the ground.i ran the motor for about 5 minutes yeasterday, it sound real good.
08-12-2011, 12:29 AM | #170 |
Re: slamburban
Looks great, you work super fast!! the muffler tip idea is a great compliment to that engine bay, where's the video of the running motor
08-16-2011, 12:18 AM | #171 |
Re: slamburban
carpet and seats
08-16-2011, 12:21 AM | #172 |
Re: slamburban
on the ground
08-16-2011, 12:22 AM | #173 |
Re: slamburban
nice
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
08-16-2011, 12:22 AM | #174 |
Re: slamburban
more pics
08-16-2011, 12:25 AM | #175 |
Re: slamburban
off to get rewired
