Old 07-28-2011, 12:44 PM   #1
1970greenmachine
2GV carb flooding
I have a 1970 C20 with Rochester 2GV carb that is fllooding my motor out. It will start sometimes but when it does it won't rev up and just coughs and spits. I noticed fuel coming out all over the carb, let it evaporate and just cranked it a bit. Fuel first started coming out the butterfly shaft on both sides so I thought something is pouring gas all over them. A flashlight showed the venturi boosters dripping heavily down onto the throttle plates. They even did it when I just injected gas into the fuel line; that's with no cranking, so no pump pressure or engine vacuum to get fuel flowing normally. What is this probably caused by? Thanks
1970greenmachine is offline   Reply With Quote
Old 07-28-2011, 12:47 PM   #2
bosco200
bosco200's Avatar
Re: 2GV carb flooding
Sounds like your float isnt shutting off the valve....has it always done this, or just started?
bosco200 is offline   Reply With Quote
Old 07-28-2011, 04:38 PM   #3
1970greenmachine
Well I actually replaced that because those nitrophyl floats can get saturated over time and not 'float', but that didn't fix it. The needle and seat looked fine, too. It seemed to start doing this suddenly. One day it ran fine then a few days later... crap!
Old 07-29-2011, 06:44 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Could be just the tiniest fleck of something got under the needle and is holding it open. It doesn't take much.
I'd check there first.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 07-29-2011, 01:26 PM   #5
bosco200
bosco200's Avatar
Yea Id take that carb back apart and really inspect the float and needle.
Old 07-29-2011, 01:48 PM   #6
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
Did you just replace the float or rebuild the entire carb?
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
Old 07-29-2011, 03:17 PM   #7
Wrenchbender Ret
The only way for fuel to flood like that is it is getting by the needle & seat. Like the guys say you probably have a tiny particle of dirt in it. Make sure the float is set right & the fual pressure is not excessive.
Wrenchbender Ret is offline   Reply With Quote
Old 07-29-2011, 03:40 PM   #8
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Did you set the float level when you installed the new float?
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
