Old 10-05-2011, 10:19 PM   #3476
57truckguy
Re: Project Vitamin C-10
My 2 cents worth.
I also have a small welder, off brand, does a ok job on up to 1/4 inch but i've( meaning my skills) are lacking in welding sheet metal. fortunately I've made an friend who welds for a living. He builds staninless steel and other metal headers for dragsters and high end hot rods.. He is a real artist.. He wants to build a set of headers for my truck with the BB but I've not seen the need thus far. Not a drag car, just a daily driver type.
57truckguy is offline   Reply With Quote
Old 10-06-2011, 12:24 AM   #3477
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by 57truckguy View Post
Alan here are a couple of pics of the GM switch I used for the brake lights. Used to have one of thoes pressure switches on the main brake line.. just didn't seem to work all the time. this has been perfect. I think it could be adapted to work on the emergercy brake.
Thanks for the pics. That will be something I do when everything else is done.
Just wanted to say that the entire interior was made, except the seats, without a sewing machine... entirely chip board and glue. After I get them reinstalled I'll send pics. if you want.
Oh by the way the holes in the panel are for the arm rest to attach to the door, the speakes mounting point and the opening handle.
Nice work on the panels
Originally Posted by McMurphy View Post
Thank you Alan, and all the others who replied about the welders. I think there is one of the Lincolns at the local hockshop for $225. I will pop in there today after work and take a look at it.
Yep that Needle Scaler is exactly what I had in mind !!
You guys rock !!
Originally Posted by 65Custom View Post
your right Allen every time I'm headed north on 575 I think the same thing too I say to myself I need to get up there and check it out
someday it will happen.
Originally Posted by Strodder View Post
Me too, but a better welder helps, along with a good welders mask.
Good safety tip.
Sorry for the crappy cell phone pics.
I took some advice off the FAQ headlight upgrade thread. I was trying to figure out a good location for the relays. The FAQ showed them behind the grill. It's a good place, but I wanted them completly out of sight. I was thinking they will be visible behind the grill. I also wanted them to be easily accessed, so I moved them up some. They are located under the panel from the headlight mount panel to the radiator support. I roughed it out tonight just need to clean it up and paint. I also mounted the fan relay there as well. The wires will be routed so they can't be seen.
Alan's Classic is offline   Reply With Quote
Old 10-06-2011, 12:31 AM   #3478
shrunken66stroker
shrunken66stroker's Avatar
Slick!
shrunken66stroker is offline   Reply With Quote
Old 10-06-2011, 10:17 PM   #3479
65Custom
yep cool idea to move them up to where they cant be seen I am a believer of the minimalist look, or clean un-cluttered look Alan is an artist
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 10-07-2011, 12:25 AM   #3480
Alan's Classic
Originally Posted by shrunken66stroker View Post
Slick!
Thanks guys!!
Got the bracket finished up. By keeping them up higher and sheltered it should keep them dry as well.
I'm trying to figure out what AWG size is required for 20 amps, from the chart I found says a 16 AWG will carry 22 amps. The conductor size is .0508. The wires on the 12v feed to the relays measures about .090" (stripped) which shows on the chart to be a 11 AWG. I feel I should match the wire size that feeds the relay from the battery.
The fan relay says 20 amps continous, but it has a 30 amp fuse.
I have some left over wire from the main harness that measures .090". I will just use that to feed the relays.
On the headlight relays I plan on feed 12v via one wire from the battery and split it to the relays. I will install a 20 amp circuit breaker on the single wire.
For those of you that are following this thread and are wiring up your truck, don't listen to me. I'm asking questions and faking it til I make it here.
Old 10-07-2011, 09:39 AM   #3481
66BowTieBoy
66BowTieBoy's Avatar
Oh Alan, it's almost as beautiful as your wood.....!
You are my inspiration...!
HAPPINESS IS A COLD BEER, A SATELLITE DISH & QUALITY TIME WITH MY DOG....!
66BowTieBoy is offline   Reply With Quote
Old 10-07-2011, 10:41 AM   #3482
Alan's Classic
Thanks Danny, do you have any inputs on some of my electrical ramblings in my last post?
Old 10-07-2011, 10:56 AM   #3483
Strodder
Daring to be Different
Strodder's Avatar
Nice job Alan. Make sure all your grounds are on bare metal.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 10-07-2011, 11:39 AM   #3484
Alan's Classic
Thanks for the suggestion Dennis, I used a lock washer under the nut to get a good bite. I checked continuity with a meter between the bracket and the engine and other body parts. It checked good.
Old 10-07-2011, 12:36 PM   #3485
Strodder
Strodder's Avatar
Good.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-07-2011, 12:41 PM   #3486
198plus
198plus's Avatar
Hurry up and get finished with the electrical..........Mines next
198plus is offline   Reply With Quote
Old 10-07-2011, 01:23 PM   #3487
66BowTieBoy
Alan, this vehicle you are building is go'na be bullet proof and should be running around the highways long after we are all Dust in the Wind...
The electrical system you have engineered would make NASA happy....
Someday I hope to attend a Rod Run in your part of the country and touch this master piece in person.
Again, YOU-B-THE-MAN...!
Old 10-07-2011, 01:53 PM   #3488
Alan's Classic
Thanks again, but I wasn't looking for compliments. . I remember you know a lot about electrical and I had a couple questions about wire size and amps that I posted earlier. Thanks
Old 10-07-2011, 02:37 PM   #3489
McMurphy
McMurphy's Avatar
Thanks for the wire guage link, I saved it to my favorites for when needed. That will come in handy I am certain!
I am soooo gonna copy cat you on alot of this stuff... except of course I like a step side.
I'm just saying...
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 10-07-2011, 05:06 PM   #3490
66BowTieBoy
Hey there Alan.
Everything I have seen you do, has been engineered with more than an adaquate cushion to perform without problems. A 14 gauge wire would work, 12 gauge would be better and 11 gauge is great. My only concern running a hot wire off the battery would be protection, and you have that covered. I got'a tell ya, I really love the wires running in the tubes.
Just keep doing what your doing....!
I know Airplane Mechanics who wish their work looked as good as yours....
Watch'n from the Cheap Seats.
Danny
Old 10-07-2011, 10:00 PM   #3491
Alan's Classic
I'm just saying...
Hey there Alan.
Danny
Thanks again Danny, don't know if you know this or not. I was a jet mechanic for 12 years.
I should have run a larger tube in some areas. There might be somemore wires to run thru them. One being the signal wire from the temp sensor to the relay. Going out to figure that out............maybe.
I stopped by Tractor supply today and looked at some wire. On the back of a pack of 14 gauge it said it was rated for 22 or 24 amps. I can't remember which. That chart said 16 gauge is good for 22. I think the package would be right. I'm so confussed.
Old 10-07-2011, 11:43 PM   #3492
Alan's Classic
Relay question. Does it really matter if I hook up 12v signal from the dimmer switch to terminal 85 or 86? It looks to me that it is just firing the coil. I have conflicting schematics in front of me. One shows power coming in on 85 and ground on 86 and visa versa.
I almost made the mistake of hooking up the red wire on the relay pigtail to the battery. Upon further investigation the blue wire on terminal #30 is the main feed from the battery.
What is the 87A terminal for? It's looking like I will have an extra wire coming from 87A which happens to be the red wire.
Old 10-08-2011, 01:13 AM   #3493
Alan's Classic
I got the 20 amp CB mounted for the headlights. Then mformed some soft aluminum tubing to route the wires for HI/LOW beams and fan relay. Thank goodness I used soft aluminum. It's so much easier to work with.
Old 10-08-2011, 10:01 AM   #3494
66BowTieBoy
Hey Alan,
Here is a little diagram I keep handy, cuz with only two working braincells, I forget a lot. I don't see where it should make any difference which direction the current flows thru the coil, it's still go'na close the circuit.
Danny
P.S. I did not know you worked on Jets, but after seeing your handy-work it does not surprise me...
Old 10-08-2011, 01:41 PM   #3495
Alan's Classic
Hey Alan,
Danny
Thanks Danny, that pic will come in handy. I'm definately more comfortable with relays since I finally underestand them. It's basically a switch.
Today I've removed the red wire from the center of the connector for 87A. If I would have realized this 2 days ago I would have moved the red wire to terminal 30 where the blue wire is now. I suppose it's not to late to do it now. I just don't like any other color than red feeding 12v.
Thought about going to the local junkyard today for some weatherpack connectors. Decided to just order them.
Old 10-08-2011, 03:37 PM   #3496
Strodder
Strodder's Avatar
[COLOR="Blue"]
That's what I did.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-08-2011, 10:42 PM   #3497
jason65
Registerd User
jason65's Avatar
Beautiful work Alan.
jason65 is offline   Reply With Quote
Old 10-08-2011, 11:40 PM   #3498
Alan's Classic
That's what I did.
It's starting to make sense.
Thanks Jason, I wonder every now and then what ever happened to you. Hope all is well.
Any suggestions here. I bought a 59 impala temp sensor a couple years ago not thinking about the connector part. It's a pin style and I don't have a connector that style. What Chevy's ran a temp sensor with a blade style? Maybe the 70's had some. Do y'all think it would work if I could locate one? I've been googling it and searching parts stores and have yet to come up with anything.
Ok, I might have found a solution here
Old 10-09-2011, 12:13 AM   #3499
Alan's Classic
I'm having second thoughts of running painted silver bumpers to match the roof. Leaning towards chrome instead. Any thoughts?
Old 10-09-2011, 12:49 AM   #3500
Vernski
My mind votes Chrome....Vernski
Vernski is offline   Reply With Quote
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
