11-01-2011, 04:54 PM | #1 |
needs more $$$
Gas Tank Options
I've been reading up on LS swaps and was wondering about the return line options. Rather than buying a new tank, would it be ok to tap into the tank's fill hose for a return line?
I don't have any real plans to do this, just trying to gather some knowledge on the subject. Also, I can't seem to find the difference between these corvette filter/regulators and the other types. Lots of mentions about them, but nothing explaining the difference. Can someone clue me in? Thanks!
1970 2wd Blazer |
11-01-2011, 08:40 PM | #2 |
Re: Gas Tank Options
I dont see a problem with using the filler neck as a return location exept the 72 & down behind the seat tanks.....Not much of a filler neck to use.
The corvette filter/regulator is used with "returnless fuel rails", The fuel pressure regulator is "built in the filter". This is only needed with 04 & up truck engines, 99-02 F-body & of course Corvette engines. |
11-01-2011, 11:21 PM | #3 |
Still Learning
I have seen this done on a few builds. (can't remember exactly which ones). They just brazed or soldered another fitting and shot it right back into the tank.
11-02-2011, 12:32 AM | #4 |
meowMEOWmeowMEOW
Thats pretty much what we did with my fuel cell. I had an extra fitting in the top that used to be for a breather; we used it as a return point and switched to a breathable cap.
And Cline, my engine is an 04 truck engine and it still has a return style system.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
11-02-2011, 10:48 AM | #5 |
in my 71 it has a 'emissions' tanke so it has a lot of 'ports' on it so I ran the return line to one of the ports at the filler neck. when filling up and the truck running you can see fuel dumping back into the neck.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
11-02-2011, 11:59 PM | #6 |
11-03-2011, 08:06 AM | #7 |
hey hey hey it all depends on what your looking for Lq4 motors are great expecially if your planning on dumping a turbo or supercharger in the future. and they also make great power with a cam swap. and lets face it dollar for dollar you get more bang for the buck caus every yahoo who has a lq9 for sale thinks its made of gold.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
11-03-2011, 09:05 AM | #8 |
bring any LQ9 to the line, we'll see what happens against the LQ4 in my heap...its just a junkyard van motor in a 40year old truck...dont be scared
11-03-2011, 01:38 PM | #9 | |
meowMEOWmeowMEOW
The only difference in the engines is flat top pistons, which ain't worth paying nearly double the price for. Only thing is you can say its the Caddy motor instead of just a "Truck" motor. Now if you wanna start to talk about the L92, then you have an argument, but the lq9 ain't nothing special.
11-03-2011, 02:50 PM | #10 |
I second that besides most are looking for a stout base to build upon what kind of bragging rights is it to say "oh yea well i got a stock lq9" WOW! a whole 345 at the crank that should get ya well into the 17 's
11-03-2011, 03:43 PM | #11 |
Still Learning
Sorry to build on the hijackedness of this thread but you guys have me wondering now. I have been looking for a 6.0 for a few years now. I haven't been able to find one in my area that is cheap enough to pull the trigger on. Exactly how many ponies are we talking about between the LQ4 and LQ9? I had thought all along a 6 liter is a 6 liter unless it's a high output version? Is this the L92 version? I'm more confused now than ever........
11-03-2011, 04:19 PM | #12 |
Truck and auto performance nut
here's a good read for you:
http://en.wikipedia.org/wiki/GM_LS_engine I've got another 6.0 not mentioned....its a gen IV with L92/LS3 style heads...an LY6. While it does have VVT (which I removed), it does not had DOD.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-03-2011, 06:40 PM | #13 |
Come on guys I was just joking
11-03-2011, 07:12 PM | #14 |
11-03-2011, 09:55 PM | #15 | |
meowMEOWmeowMEOW
For me the advantage of the truck block was the most displacement I could get, at one of the lowest price points. You can usually buy a complete lq4 + cam kit for less than an lq9.
11-04-2011, 11:57 AM | #16 |
the LY6 also has slightly higher compression, 9.65:1 vs 9.4:1 for the LQ4.
pistons are also cut with valve reliefs for the bigger L92/LS3 heads valves
11-07-2011, 03:40 PM | #17 |
needs more $$$
Thanks for all the talk guys...I've been on the board for a long time, but never this portion of it really. I've always wanted EFI in my ride for the sake of it just starting easy, possilbe mpg gains and just plain cool factor. My ride starts right now easy with 2 pumps of the gas pedal, and I don't really need/want added HP as it's just a cruiser...so I'm wondering if the time and $$$ is worth a LS swap in my situation....opinions?
My question came because I have a Boyd tank right now, but it's not set up for EFI and I don't really want to drop $$$ in another one and was considering a cheaper alternative.
1970 2wd Blazer |
11-07-2011, 05:10 PM | #18 | |
Still Learning
11-07-2011, 06:02 PM | #19 |
C10 Club Tennessee
I'm also interested to see what other tank options there are. I have a 72 burb and just dropped my old one today. Just curious of what other applications would work. I'm doing a budget swap.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
11-07-2011, 06:23 PM | #20 | |
needs more $$$
Oh...and I probably could sell it but there's already a dent in it from when I let my brother drive it...
1970 2wd Blazer |
11-07-2011, 10:40 PM | #21 |
cheapest way is to run a camaro tank and pump the whole set up cost me 90 bucks
11-07-2011, 10:58 PM | #22 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-08-2011, 01:28 AM | #23 |
C10 Club Tennessee
Do you know of anyone running this setup?
02-05-2013, 10:08 PM | #24 |
what year camaro tank did you get?
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs) 00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs) |
02-05-2013, 11:17 PM | #25 |
I used an 02 camaro on my swap, worked out real well.
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
