Old 11-18-2011, 12:25 AM   #1
Jemo
If you ever want to change the cam in a LS motor....
I did it this weekend and it was easy, easy. I've never done a cam swap before but just followed the instructions here:
http://www.ls1howto.com/index.php?article=23
Follow them exactly and get the recommended longer crank bolt - you definitely need it for removing the crank pulley and putting it back on. Other tips:
Buy one stock crank pulley bolt for your motor from dealer
Buy the longer crank pulley from the dealer. I don't know the part # but it's out of a LS7 7.0L Corvette. 125 mm long. The stock bolt is 103 mm.
To keep the lifters from falling, use the Russian Roulette method he describes in the link but then insert a long piece of 1/4" brake line in the two holes on the front of the engine. Works as well as the $100 rods that do the same thing for a lot less money.
Unfortunately for the valve springs, I tried to use the rental tool from the parts store but it was no help. I bought the $100 Comp Cams tool and it's worth it's weight in gold. it does 2 springs at once so it goes quickly and it's for an LS motor so it works.
Take your time!
Jeff
'59 Big Window Fleetside
Jemo is offline   Reply With Quote
Old 11-18-2011, 12:37 AM   #2
LEEVON
LEEVON's Avatar
Re: If you ever want to change the cam in a LS motor....
what do you want for the comp valvespring tool? I have a custom made tool but it does one valve at a time and I don't like how it seats...
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-18-2011, 01:03 AM   #3
Jemo
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 11-18-2011, 01:12 AM   #4
OldJimmy57
Ah a fellow Dallas Texas member
http://67-72chevytrucks.com/vboard/showthread.php3?t=145432
OldJimmy57 is offline   Reply With Quote
Old 11-18-2011, 01:17 AM   #5
Slowtruk
Slowtruk's Avatar
You are right, doing anything to the LS style engine is easy. Just not easy to tear them up. They are some well designed engines
IBEW Electrician-Nick
1985 C20 Silverado
1965 C-10 short fleet
1961 c-10 Apache short fleet
2005 Chevy Suburban LT
2012 Hyundai Sonata
Slowtruk is offline   Reply With Quote
