Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 01-04-2012, 10:38 PM   #226
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Re: Post your best budget mods! ($50 or less)
Originally Posted by stfinney View Post
When painting the dash cluster, what do you do about the lettering and numbers?
That's all printed on the lens you can just repaint the tins and it's all good.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline
Old 01-04-2012, 10:41 PM   #227
stfinney
stfinney's Avatar
Ah, ok. Never had one apart, so wasn't sure. Thanks!
stfinney is offline
Old 01-05-2012, 09:18 AM   #228
72ArizonaBurb
Subscribing!
72ArizonaBurb is offline
Old 01-10-2012, 06:35 AM   #229
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
subscribed
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline
Old 01-10-2012, 08:09 AM   #230
blkcorvair
blkcorvair's Avatar
Just posted this over in truck audio. Add an Aux jack to your Stocker radio for $20 or less!
http://67-72chevytrucks.com/vboard/s...d.php?t=502427
blkcorvair is offline
Old 01-10-2012, 12:21 PM   #231
70STOVEBOLT
70STOVEBOLT's Avatar
Wow, I never would have guessed it would be that simple. Do you know if aftermarket radios/stereos use the blue wire also?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline
Old 01-10-2012, 01:00 PM   #232
blkcorvair
blkcorvair's Avatar
If I understood correctly, Radios that use the turn know sytle potentiometer can al get this mod. You have to isolate which wire is the signal "in" and install in that circuit. It may not be blue in all radios. But if I am correct they would have three wires. One is a ground (Usually black) and the the input signal would be the third wire (Farthest from the ground)
I have heard that you could bech test and remove one wire at a time and try it on each circuit to find which wire gives you the result, than install the AUX jack circuit there.
Old 01-10-2012, 01:26 PM   #233
70STOVEBOLT
Very cool mod, thanks for the info.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 01-10-2012, 02:33 PM   #234
Coley
Coley's Avatar
Smile Re: Post your best budget mods! ($50 or less)
Is it just me....or is it that its always more interesting and fun as to what you can do and create with less money....than more.
Great post by the way and I'm going back through my mental archives to think of my best $50 (or less) endeavor on my truck....hmmm.
Keep 'em coming!
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline
Old 01-10-2012, 04:17 PM   #235
DT1
DT1's Avatar
Not the best budget Mod but worth while. I rigged up this oil separator for my PCV line. I got the separator from Harbor Freight and made a bracket to attach to the intake manifold. The total cost was under $12.00.
DT1 is offline
Old 01-10-2012, 04:45 PM   #236
shawno72
C/10 junkie
shawno72's Avatar
You want some super bright dash lights for cheap and no leds? I'm cheap so what I did was took my cluster apart and everything that was pale green I painted white. Next after I re-assembled the cluster I replaced the standard 194 bulbs with 921 bulbs. They fit perfect into the light sockets but are much bigger. Cost less than $10.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 01-10-2012, 04:58 PM   #237
kikkegek
kikkegek's Avatar
Attachment 854155
problem with those bulbs maybe that they also produce equally more heat as light. So be sure not to burn the back of your guages...lot of plastic in there.
kikkegek is offline
Old 01-10-2012, 06:50 PM   #238
shawno72
C/10 junkie
shawno72's Avatar
Been running them for years with no problems so far, but if cash is not the issue you can run the LED's.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
shawno72 is offline
Old 01-10-2012, 06:51 PM   #239
DT1
DT1's Avatar
X2...I learned the hard way on another vehicle.
DT1 is offline
Old 01-11-2012, 05:51 PM   #240
CMFK72
CMFK72's Avatar
subscribing...
CMFK72 is offline
Old 01-22-2012, 06:28 PM   #241
KY Colonel
KY Colonel's Avatar
Originally Posted by KMACD71 View Post
Can of white paint, bottle of orange model paint and brushes for the needles and you can brighten up your bezels and I believe with the LED bulb swap you can still be under $50.00.
That ROCKS!
1970 K20 Custom 427/TH400/PS/PB and a dash of badass!
I was made in America, my truck was too...4 years before me.
KY Colonel is offline
Old 02-05-2012, 11:05 AM   #242
rpmerf
rpmerf's Avatar
More of a repair than a mod, but here it goes...
The shifter was loose in my truck. I pulled off the linkage where it connects to the column and noticed there was a bit of a gap. The bushing on the bolt was 1/2" and the hole the bushing was in was 5/8". I found a 1/2"x5/8" plastic bushing at home depot for $0.50!
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline
Old 05-11-2012, 02:11 PM   #243
zellway
zellway's Avatar
Don't know if this is what some would call a mod or not. I install DOT tape inside my tail lights and dash bezels to help make it brighter. I will take a pic with in all installed. You can get it all over the place well under 50 bucks. Stuff sticks to about anything and will hold up fine in the heat.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Old 05-11-2012, 03:52 PM   #244
Mayo
Cool Truck
Mayo's Avatar
Does it make it much brighter? I might have to try that, and think I have some of that tape from work.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline
Old 05-11-2012, 04:28 PM   #245
zellway
zellway's Avatar
Big time! silver paint works ok, but this stuff rocks. Next time you are around a trailer with DOT tape on it shine a flash light on it and you will see how well light will shine back.
Erik
zellway is offline
Old 05-11-2012, 05:43 PM   #246
Mayo
Cool Truck
Mayo's Avatar
I know that it shines. All of our dump trucks at work have it and I covered some magnetic bowties with it for my rear bumper.
Mayo is offline
Old 05-11-2012, 05:55 PM   #247
zellway
zellway's Avatar
My 78 blazer has a bowtie out of red and looks cool when the light hits it. Might be illegal to shine red up front but no one has pulled me over yet. Its more a off road truck any way. I wounder if putting on as the letters on a tail gate would be too much?
Erik
zellway is offline
Old 05-14-2012, 11:03 PM   #248
velociraptor
velociraptor's Avatar
count me in...making a shopping list, lots of good stuff going on in here
70 c20 jager with.....well i dont know what the motor is yet?? (found the partial vin...shows up as a 75 350)
velociraptor is offline
Old 05-15-2012, 11:23 AM   #249
tankerchief
Just spent $50 on a 3/4 ton sway bar. all the mounts and bushings were in great shape. Best money I have spent to make my 69 to stop wallowing in the curves! Night and day for 30 minutes of work to install. Best mod ever!
1952 Chevy 3100
1969 Chevy C10
2006 Chevy 1500
tankerchief is offline
Old 05-15-2012, 07:35 PM   #250
waybad
waybad's Avatar
subscribing!!
waybad is offline
