01-15-2012, 01:48 AM | #1 |
Alan Grove brackets
Test fitted my Alan Grove brackets today. Since I don't have bolt holes in the heads of the '65 corvette 327 I picked up, I put these brackets on. They worked out very well and I was impressed enough that I might put them on my 383 as well. Now I have to decide if I am going to powder coat or plate them. The engine is dusty from sitting in storage, but rebuilt. Got a suprise when I found that one of the bottom holes in the block was stripped out. Thank goodness for heli-coils.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed Last edited by rbar; 01-15-2012 at 01:49 AM. Reason: .. |
01-15-2012, 02:17 AM | #2 |
Senior Enthusiast
Re: Alan Grove brackets
I purchased Alan Grove brackets back in 2000 and had them powder coated before installation. Other than grime from use, they look like new when cleaned up. Since the metal is so thick it really heats up nicely and does a great job curing the powder paint. Plating would certainly add more sparkle if it's in the budget.
01-15-2012, 02:21 AM | #3 |
I'm talking zinc plate vs powder coating. I can do either one of those two at no cost.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
01-15-2012, 02:40 AM | #4 | |
ron |
01-15-2012, 02:48 AM | #5 |
I believe that is what he has ron...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
01-15-2012, 03:02 AM | #6 |
01-15-2012, 03:23 AM | #7 |
Hey by the way what you been working on lately....ron, I not sure you`ve posted a project lately...?
01-15-2012, 09:17 AM | #8 |
I really like the brackets, did you buy it as a kit?
01-15-2012, 11:45 AM | #9 |
Yes, from Alan Groves components. It's for long water pump only. It's $70 for the steering pump. It's $45 for the alternator, but if you don't have a bolt hole in the head, then you have to buy the $25 bracket that goes on the back side of the alternator and uses the two bolts that hold the water pump on. It was all $152 shipped.
01-15-2012, 11:57 AM | #10 |
Resistance is Futile
rbar, is there a bracket on the back of the power steering pump?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-15-2012, 12:18 PM | #11 |
Desert Dweller
Looks good
I have a Alan Grove A/C compressor bracket and it is a quality piece. Posted via Mobile Device |
01-15-2012, 12:27 PM | #12 |
The long pump normally works with the thick balancer. The 327s had the thin balancer. How did you work out the issue with pulley/belt alignment? I tried that on my own years ago, and it was a nightmare. Does Grove make brackets specifically for that application? I would have paid huge money for those back in 1984......
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
01-15-2012, 03:12 PM | #13 |
Yes, it looks just like the "triangle" shape that is on the front of the block and it is flat against the block mounting holes, but one plate is 3/16" thick and the other 1/4". It is very sturdy, at least when I try to move it around by hand.
01-15-2012, 03:21 PM | #14 | |
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed Last edited by rbar; 01-15-2012 at 03:29 PM. Reason: .. |
