#51 |
Re: 67-72 Chev Crewcab Build
Wow! That is awesome!
I'm really digging the 4 doors!, there was a snapshot of one in the latest issue of Classic Trucks (article about Bonneville Salt Flats). Damn nice looking. |
#52 |
Love the look of the cab looks amazing.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
#53 |
GEARHEAD
Great idea doing all that work with the skin off.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#54 |
#55 |
Junk Yartist
did you lap weld all the seams?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#56 |
In some places I did , but only where it was needed. I tend to over weld things as it is.
Randall Cowboy the 70' Crew Cab The DUKE K50 Crew Cab 2nd gen build thread Drill Sergeant The Ponderosa |
#57 |
Junk Yartist
No such thing, Ha! Did you have any issues with warping? I really like the idea of flanging and lap welds with spot welds. I't should be extra strong. I'm probably going to pick your brain all the way through this build. I can't wait to see what you do for your window frames!
#58 |
Your killing me with all that your getting done. I don't have any time right now to work on my.
Posted via Mobile Device |
#59 |
6>8 Plugless........
![]() Join Date: Sep 2007
Great work! I was curious what you were going to use for a skin. I assumed a donor piece from the burb just where you are going to use. The burb donor I'm getting has big dents in that area. So I'm wondering if it would be better for me to use an old box side, or I need to find another burb to hack that section off of.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#60 |
Weezer I couldn't imagine doing it any other way.
Regarding lap welding; lap welding in this particular case is not necessary where ever a joint turns and goes in a different direction you can see that as a reinforcement lap welding on sheet metal is hardly necessarily especially when you consider spot welding with a mig welder is way more effective than factory spot welding. Before I button up the door I will go back through and check all areas for flex. Regarding the question about warping; I never spot weld more than three in a row before I move somewhere else and then come back, I also use an air blower to instantly cool the weld when I think warpage could happen. Regarding flanging; is there really any other way. I broke my flanging tool earlier this week trying to flange into a corner, stopped what I was doing and went and replaced the tool instantly. The hole punch on the flanging tool is invaluable wouldn't even think about doing this job without a high quality flanging tool. Regarding the window frames; if you look back on the window frame pictures the window frame is done. It was a cake walk. Regarding how quickly I am getting this done; nothing quick about it but this is my living. Ryan yes I did use the skin behind the driver's door because the body line is consistent; you need 35 inches continuous I don't know if a bedside would work or not. Just after 9:00 on Saturday getting ready to roll out the rotisserie and do some media blasting. Mainly the roof and the inside of the door and then I will be pulling it back in and finishing the door. All future crew cab projects will be media blasted before I start any work. Getting tired of smelling burnt paint and welding is a lot easier when there is no rust or paint. Always remember guys my shop is always open to visitors just be careful I might put you to work. Looking forward to building myself a 70’ 4 door one ton 4wd burb.
#61 |
Junk Yartist
Thanks for the info!
#62 |
Looks great. What is your wheelbase now?
#63 |
160" hub to hub.
#64 |
This will be a great truck! Cant wait to see it done.
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
#65 |
Thanks Les. I can't wait to drive it
#66 |
Tot Roddin'
Awesome...
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#67 |
VA72C10
![]() Join Date: Mar 2008
Awesome work!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#68 |
Nice work, I wish I had 1/10th of your skill.
Are you planning on building cabs for sale?
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#69 |
Rtechfabrications.com
#70 |
Thank for the quick response. You have now given me something else to save for.
#71 |
Thanks for the info and continue the great work!
#72 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#73 |
Rob,
I have looked at this from many different angles and lets face it this door is already well over 100 hours to build. I don't see a way of doing it that will clear the latch mechanism and the hinge indentation on the front, I had one guy ask me if you could completely do away with it, I would say no it would look really weird with a big piece of glass in the back and a small piece glass on the front door.
#74 |
Just got done painting seamsealing and rubber coating the inside of the door, will probably try to have the door skin on by the end of the day.
#75 | |
