#126 |
![]() Join Date: Oct 2011
Re: "TANGERINE" (C20 to K10) (LWB to SWB) (CST/MOD) (5.3)
Then I welded on the patch panel using my gauge to set it in place.
, , ,, , , I built the gusset to go inside the channel of the pillar to add a little extra strength to the connection. , ,, Here is what it looked like welded into place. , , ,, , And finished off. , ,, ,
Wade , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
#127 |
So then I fabbed up my "B" pillar patches.
, ,, And welded them in place. , , ,, And then I finished prepping the eighth inch thick inner rocker panels, , , ,, and welding the left one into place, which is where I ran out of time, so I'll probably weld the right one on in the next day or two. , , , , , ,, , ![]() , ,
#128 |
67cheby
![]() Join Date: Sep 2008
GREAT idea, and impressive work !!
#129 |
6>8 Plugless........
![]() Join Date: Sep 2007
Great work! That'll make it pretty stout too!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#130 |
Still plays with trucks
Good idea with the 3D locating fixture. Nice work.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#131 |
Nice job on the pillar patch, that hole jig looks like a much better deal than taking sloppy measurements and beating my head on the wall. Your B pillar looks pretty sweet too and it fit! unlike the taiwanese version. I haven't got my B pillar in yet maybe this weekend.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#132 | |
Ammo is getting too expensive for my .308 ![]() those rear curvy windows are $150 locally (same as 4dr wags) only one is missing, used ones have the classic yellow bubble effect between the panes though. I found a "new" supplier for those out in cali and they quoted me like $450 each? i think. they said they would consider shipping but no guarantee on breakage but they could bring some when they come back for another auto show. Nice job on the pillars !
#133 |
Thanks 67cheby!
![]() Thanks Dieselwrencher, stout is what I"m shooting for! I figure that the eighth inch steel will make easier to weld to. (no burn through's) Yeah it works great, just be sure not to bump into it after the end piece is cut off.
#134 | |
#135 |
Still Learning
Nice work with all the new metal Wade. Sorry for your bad experience with the trash can company. I have had my share of trouble with the parts they sell more than delivery issues.
#136 |
Awesome build!
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
#137 | |
![]() Thanks OLDIRON69!!
#138 |
Some pics of my brother's "Magna Bend",,,,,,,
,, In action!!! , , , , , ,, Lucky me!
#139 |
That thing is sweet! I want one!
#140 |
Me too. That is a nifty toy for sheet metal.
#141 |
67cheby
Sweet !
#142 |
You can make alot of cool parts with a brake like that!
#143 |
That Magna Bend looks pretty sweet, Ive looked around at getting one for home use and that would be great, they have a similar chinese one at tractor supply. I use 135 ton hydraulic press brake at work but sometimes they get a little snarky about making personal projects.
#144 |
Still Learning
I'm digging that brake. I could sure use one of these in my shop.
#145 |
Thanks for compliments on Magna Bend (and my brother thanks you). He also has a plasma cutter just in case I go completely nuts and start working on a total basket case!,, (Mcbassin)
![]() Update on Tangerine,,,, I didn't get a whole lot done over the weekend,,,it turned out to be one of those weekends where everything I've been putting off finally catches up to me. I went in and worked on it tonight, I patched in and smoothed out those panel gaps at the corners of the windshield frame. (what a lot of work!!) Special props to "theastronaut" (board member), (frick'n mad skilled genius!!!) for some insight on this body work. And I repaired some rust in this area. I know that some of you guy's are getting anxious to see this cab merged with the floor/firewall, so am I. It's real tempting to put them together now that both inner rockers are in place, but now is the time to get all the tedious body work done while I can easily reach all these area's that need attention. Hang in there a little longer, I'll get this stuff knocked out pretty soon!
#146 | |
#147 |
Updates ? haven't heard from you in a week, you must be busy working on this badboy right??
#148 | |
, ,, , I finished up the transition between the drop panel and the cab corners. , , ,, , And smoothed out (the gaps) and repaired rust around the windshield. , , ,, , And I smoothed out the overlap lip at the back of the cowl. , , ,, , Now your pretty much caught up, I'm still in the process of fixing a few dents and other body work. Like I said I'm kinda slow, but I don't want to do this again anytime soon, so I'll keep plugging away.
Wade , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro Last edited by fakerwade; 02-14-2012 at 10:14 PM. |
#149 |
Side note; I sold my seat (I'll be using the Yukon seats) to a guy that works in the same building as I do.
, ,, He re-upholstered it and put it in this truck, it's for sale. , , ,' It has a small block that's been dyno'd at 485 h.p. and has a 5 speed racing trans. Pretty nice truck. ($11,995)(208-746-7040)
#150 |
Not a bad price from what I have been seeing.
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
| Bookmarks |
