03-04-2012, 08:44 AM | #1 |
BBC swap...
Could someone give me a list as to what I will have to change to put a 454 BBC in my 71 c10 350/350 turbo? I have heard a ton of things will work/wont work things like my radiator,mtr mounts,ect...Thanks
Any do's and dont's you guys know let me have em!! |
03-04-2012, 09:17 AM | #2 |
Loves all GMC trucks
Re: BBC swap...
It really depends on a few things, like do you want it to be year correct? I'll guess no since it's not a 402, so I'll add a few and others can jump in:
Motor mount towers Radiator and radiator mounts (unless you have a three/four core) Fan shroud Depending on what motor you use you may have to extend the alternator wires, if it's a pass side alt If your going original, then there are additional things: Pass side heat shield Exhaust manifolds Alt brackets P/S brackets A/C brackets Exhaust hangers This should get you started, I'm sure others will jump in. This board has many of the best people you could ever meet and if you are looking for parts you can find them on the parts board. I suggest reading the FAQ threads too. It saved me from making a lot of mistakes. Welcome from Kansas... Mike Posted via Mobile Device |
03-04-2012, 01:45 PM | #3 |
Junior Member
Re: BBC swap...
When we put a complete '73 454 in my '71 we used the motor mounts for the '73 so the headers would clean.
By complete I mean the engine had everything except a carb. We did not want to have to have a new drive shaft made so we mated the engine to transmission and let the engine settle into the frame and drilled new holes for the motor mounts. I already had a 3 core radiator so we did not have to replace it. We used the fan shroud from the '73 truck, but did have to modify it some to clear some of the pulleys. We did have to extend the alternator wires over to the passenger side from the driver's side. Everything worked out pretty easy actually for us.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
03-04-2012, 10:12 PM | #4 |
Re: BBC swap...
I should have posted that this motor is complete carb to oil pan with alternator and brackets and headers. I'm assuming I will need to upgrade the rearend to a posi and maybe a gear change I think the rearend is stock what about axels?
03-04-2012, 11:42 PM | #5 |
Junior Member
Re: BBC swap...
I did not change the rearend, it is a stock 3.73 non-posi. The engine is mostly stock except for the headers.
