04-09-2012, 07:51 PM | #3826 |
Re: What did you do to your truck today!
I finished up my 4 speed swap Saturday, knowing I'd have to pull the driveshaft again to replace the U joints, I had to make the rear section of the driveshaft to mate it to the 10 bolt. I spent a couple hours at the junkyard trying to find one the length I needed with no luck so some work with the grinder and chopsaw and welder and I was in business. The carrier bearing looked to be pretty decent still so wasn't too worried about it. Drove it to church yesterday morning then out to eat and to the parts store to pick up the U joints and rear brake shoes. Dropped my wife off at the grocery store and ran to get gas, that's when it happened, the carrier bearing seized and spun the rubber out of it. Limped it to home as it wasn't slapping around too much till later. Took it out and beat off the old bearing and called it a day. After my morning class today I stopped and picked up a new carrier bearing. Got in this afternoon from my bus route and got the new front U joint in and the new carrier bearing on and put in the front section of driveshaft. Hopefully tomorrow I'll get the the other two U joints in and the rear shaft back in the truck. I love the truck with the 4 speed now! Next is replacing the rear brakes. Then I'll move onto new rockers and cab corners!
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
04-09-2012, 11:15 PM | #3827 |
New steering wheel
1971 chevy c10 ECE 4.5/6 dropped 1970 suburban ECE 4/6 Dropped 45K original miles so far 1948 Ford Sedan 1941 Dodge COE 1932 ford roadster the rest are normal drivers |
04-09-2012, 11:43 PM | #3828 | |
04-10-2012, 12:48 AM | #3829 |
I got my radiator support and radiator installed today. I bought an Entropy radiator with 1.25" tubes...man, that sucker is huge. It just fit (tightly) into the 4 row core radiator brackets. My truck is starting to look like a truck again.
04-11-2012, 07:14 AM | #3830 |
Battery is in, fuses are in , radiator pressure is good. Just sent out bumpers to be painted, get them back tomorrow. Start engine on friday!!! Need to install innnerfenders, bolt down seats and connect fuel line to gas tank. Ordering reese hitch today,. Still waiting for some chrome parts but it won't stop me. First car show April 22. I will be there hell or high water. Say a prayer for me.
I know I can! I know i can! 72 K20 Restoration |
04-11-2012, 02:39 PM | #3831 |
As of 4pm today she will be sold! back to the original owner! going to miss her! but hopefully something better awaits!
04-11-2012, 06:26 PM | #3832 |
Junior Member
A local guy that restores these old trucks stopped by for a while. We went over to the shop and looked at my '67 cab on a swb '69 frame and talked about how I can fix some rust issues.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-11-2012, 06:42 PM | #3833 |
Newbee
Yesterday I took the truck for a little cruise. I quickly found out that it has become a fair weather pansy! After about 20 miles in 95* weather things got a little heated. 215 on the motor, and 210 on the trans. This simply will not fly!
I came home a little irritated, removed the grille, and installed two plate style tranny coolers. Today, I ordered a high volume water pump, a 6 blade 19'' fan, super duty fan clutch, and a build it yourself aluminum fan shroud. I added to the order, a selection of high flow thermostats. This truck will be able to cruise in 118* with the air on full blast! If this won't fix it, I am building a new motor, that is not .060 over! |
04-11-2012, 10:13 PM | #3834 |
Added power steering to my 70 C10. A previous owner had installed a 350 out of a van and it still had the power steering pump, so I just had to get the correct hoses and a gearbox. Picked up the gearbox over the weekend when I went to pick up a pair of CST doors that I found on Craigslist. Surprisingly easy conversion! Now I just have to figure out how to get my steering wheel to sit straight when the wheels are centered....
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold |
04-12-2012, 01:17 AM | #3835 |
Big Red - Now its a SWB!
Took my truck on a cruise for the 1st time since new years. Didn't realize how much I missed cruising the old truck till I took off from a stop sign and lit up the tires in 2nd, 3rd, and 4th gear and didn't straighten out until I was doing 60 MPH.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
04-12-2012, 02:05 AM | #3836 |
Hated the wood grain steering wheel that came with the truck, and don't have the extra 450 for a billet steering wheel so I figured I'd give this a try and painted it the same color as the truck... Not to sure on how I feel about this
Posted via Mobile Device Posted via Mobile Device |
04-12-2012, 08:33 AM | #3837 |
67cheby
I like it painted
04-12-2012, 08:40 AM | #3838 |
X2, bug what color is that?
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
04-12-2012, 08:51 AM | #3839 |
I have the day off some I'm going in! Air conditioning-You will be mine!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
04-12-2012, 08:52 AM | #3840 |
Last night I worked on fabbing up my 3" exhaust (with an X pipe). Man I wish I had a lift. All that trial fitting, crawling under and out over and over. That 3" takes up alot of room but I got it all tacked together and pulled out to finish up the welds...and then ran out of wire! Grrrrrrr....
04-12-2012, 09:47 PM | #3841 |
04-12-2012, 10:00 PM | #3842 |
I put the right door back on my 70 stepper all by my self with the help from a cheery picker.( necessity is the mother of invention)
04-12-2012, 11:29 PM | #3843 |
Put the steering wheel back in
04-12-2012, 11:46 PM | #3844 | |
I really like it! Good choice Posted via Mobile Device
1971 chevy c10 cheyenne. Bagged. New paint and some other mods. 1999 ford f350 superduty 7.3 powerstroke everything banks 1975 c10 swb "parts runner" <----SOLD NorthWest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ |
04-13-2012, 12:45 AM | #3845 |
Wasn't sure on the picture of painted steering wheel, but installed it really fits in and isn't to much at all, good choice painting it.
04-13-2012, 04:07 AM | #3846 |
I stopped by paint shop and he was painting my bumpers, I will be painting back side tomorrow and then bolting them on. Spent time glass beading my mag wheels and hope to have them mounted tomorrow. Painted inner fenders and bumper brackets today. I am still waiting for a shipment from LMC which will deliver the fuel sending unit and then I can start truck saturday morning. I grounded the bed , cab and radiator support andf fixed water leak on block. I think i will have it ready for car show on 22nd.
04-13-2012, 10:24 AM | #3847 |
Junior Member
Got a parts truck for my '69 over the weekend, so I spent the other night taking the front end of that apart. Did a little spot welding to cover up the side marker lights on the right bedside. BTW 74baggedbug, love that color. Never was much a blue fan till lately, but that's a beautiful shade of it.
1969 CST-10 - "Glory Bound" - build in process (slow going) 1971 Cheyenne 10 2006 GMC Yukon XL Denali Isaiah 46:4 - I will be your God through all your lifetime, yes, even when your hair is white with age. I made you and I will care for you. I will carry you along and be your Savior. |
04-13-2012, 08:16 PM | #3848 |
20' Daredevil (Ret)
The old battlewagon has been sitting a lot lately. Gotta get it ready for firewood, had to charge the battery to fire it up. Brakes have been on & off mushy (pedal going down too far, have to pump to get good pedal -- just part of the time). So I recruited my wife's help and we bled the fronts. Didn't notice any air in the lines (bleeders were both plugged though). Took it for a short drive and it's about the same.
Siggghhhhh...... didn't really want to pull the rear axles to bleed the back brakes. The MC is just a few years old so I *think* it should be okay.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
04-13-2012, 09:48 PM | #3849 |
Well it wasn't today, but last Saturday I replaced a left rear wheel seal and the right rear wheel cylinder. Then on Tuesday the muffler blew apart. So it looks like this weekend's project will be exhaust work...
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
04-13-2012, 10:15 PM | #3850 |
Nothing.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
