Factory Air Pres gauge for bags?
I have recently bought a set(4) of Dominator 2600 bags for my '69 SWB. I really want to use a cluster that includes a factory gauge from one of the big trucks to maintain a stock appearance. Has anyone done this with success? I have 2 3 gal tanks with Viair 400 compressors.
#2 | |
Re: Factory Air Pres gauge for bags?
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
My gauge is to 150# as well. I know it will work with 1 tank but will need to somehow get another to measure the other tank? Or is there anyway I could tie the two tanks into one gauge?
Posted via Mobile Device |
If they are teed together, they will be at the same pressure
Would there be anything wrong with that?
I think it's typical to tie the tanks together for more available air volume. I can't think of any good reason to leave them separate.
Thank you for the input. I couldn't think of reason not to but I am still new to air.
I'm new to it too, only have my bags installed so far but no plumbing, valves, tanks or compressor yet.
Just got the rest of my kit in today. I hope to have them on tonight!
needs more $$$
If the gauge only goes to 150, I'd plumb in some type of pressure valve so you don't send more than 150#'s to the gauge and potentially break it. If that fails, then you'd have a leak in your tank and your comps would not turn off.
1970 2wd Blazer |
Great suggestion Tubbed. I would probably cry if my brand new gauge blew up.
1956 GMC undergoing LS Swap |
