09-23-2003, 12:30 PM | #1 |
Bed mounts needed
I need all four bed mounts for my Short Fleetside box. The mounts are the ones that are riveted to the frame that the bed mounts to.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
09-23-2003, 02:29 PM | #2 |
Can't kick the addiction!
If the bed mounts are the same as the short step side mounts, then I have a set of bed mounts that I can remove from a frame I have.
09-23-2003, 03:21 PM | #3 |
CCRider
What is a bed mount? My fleetside bed just bolts to the frame
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
09-23-2003, 03:46 PM | #4 |
The bed mounts we are talking about are the brackets that are riveted to the frame that the bed cross sills sit on (located before rear axle). The pair closest to the cab should mount flat on the flat section of frame and the 2nd pair should mount on an angle on rise in the frame before rear axle.
09-23-2003, 03:49 PM | #5 | |
I will have to check on this. I am not sure. I think they are the same.
09-23-2003, 05:04 PM | #6 |
I have all the mounts you need already removed from frame. If interested just let me know.
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2024 Chevy Tahoe Z71 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 Last edited by TxGary; 09-23-2003 at 05:38 PM. |
09-23-2003, 05:37 PM | #7 |
Here is a picture of the mounts that I have.
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2024 Chevy Tahoe Z71 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
09-23-2003, 08:07 PM | #8 |
TxGary-
Let me know what you may want for themand if youcould ship. Thanks
09-23-2003, 08:17 PM | #9 |
TxGarys parts are correct for short fleet & step beds. We have pretty much any mount,crossmember,hanger,a arm,trailing arm,coils,leafs etc. for 2wd 1/2 and 3/4 short or long bed truck in stock on the shelf for future reference. No 4x4 at all.
Rest in Peace Ed. Thanks for all the good times. |
09-23-2003, 11:16 PM | #10 |
Bowtiefreak, sent you a PM on parts.
