#26 |
Re: LT1 in a 55 2nd series w/77 camaro clip?
Hey Shane think about using this bracket instead.....looks like alot less work than alan groves design and uses all stock components. http://www.brrs.efishant.com/index.p...pper&Itemid=60
#27 |
![]() Join Date: Sep 2011
Thanks Izonme13! This is why i love this forum so much... so much valuable knowledge out there. Ordered the kit today!
-Shane |
#28 |
No problem.....Im picking mine up in a couple weeks, they are only 4 hours away from me. Robert
#29 | |
#30 |
Hey Guys -
I got some work done on my project 55/LT1 swap... Engine is in.. but sits really low.. It bolted right up to the factory Trans Am engine mounts, however I am most likely going to need to raise it for header clearance....thought I'd drop some pics. I need some help with the wiring harness... Question is do i get the factory harness from the 1995 Camaro modified to fit or go with a brand new one? I've been recommended to www.wiringharness.com and www.currentperformance.com (which is the company that modify's the harness).. they also reset the computer so the engine will run. Would love some feedback! Thanks! -Shane |
#31 |
Check out street & performance for engine harnesses. I myself will be using the stock harness &the have the ecm flashed. Also using an aftermarket harness for the truck. The ecm can get the power from that. Havent got that far, but got this info from alot of researching. My 02¢ worth.
Posted via Mobile Device |
#32 |
![]() Join Date: Mar 2007
I went with a wiring harness and reflash from Howell Engine Development.
http://howellefi.com/ They were great to work with. It was not cheap (close to $700 total) but I didn't want to go with a hacked up harness. I even had the factory wiring diagram. I also wanted a longer wiring harness to hid the computer inside the cab. Here is mine... Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#33 |
Got my harness built and computer programmed at lt1wiring.com
#34 | |
#35 |
CENTRAL AIR CONDITIONING IN MY SHOP. so ive been working on the 55 more.
ive got the core support on the drivers side finished finally. now im goin to try and do some rust repair. allready did cab corners and one rocker panel and step. noticed that previous owner took a hammer to the firewall and messed it all up so im goin to have to replace the whole thing and make a trans tunnel. first time ive every done any body work here it is ![]() how the motor sits ![]() here is the LT1 Harness they made for me ![]() Last edited by WONKA1955; 06-15-2012 at 12:26 PM. Reason: adding pictures |
#36 |
Navy Radioman Veteran
Nice thread... I'm adding an the 350 out of my 87 pickup that I put a 454 into. It's a throttle body motor so I'll end up with FI in the '57 when I'm done. I'm still cleaning the frame prepping for the '78 camaro clip and '73 Jag XJ6 rear right now. I'm a bit from drivetrain work... Keep the pics coming.. great info!
Subscribed, Ken.
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
#37 |
Looking good.
I see you have a list of to dos on your bench. Kim |
#38 |
been trying to figure out a fuel system (pump and tank), brakes (booster,ect.),and which steering column on a budget. also the pedal assemblies.
#39 |
[QUOTE=WONKA1955;5435919]CENTRAL AIR CONDITIONING IN MY SHOP. so ive been working on the 55 more.
ive got the core support on the drivers side finished finally. What did you do to it? Was it because of the steering box? How about some pics!! |
#40 | |
#41 |
Picked up a seat, and wheels for $200. Also here is a pic of the core support almost complete
![]() ![]() ![]() Posted via Mobile Device |
#42 |
I sent you a PM on a measurement on your clip. Thanks
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
#43 |
Looking good. Nice score on the seat and wheels.
Kim |
#44 |
I'm goin to clean it up and box it in but here is a pic of the 77 clip meets the frame
![]() Also shortened the clip ![]() Passenger side ![]() Posted via Mobile Device |
#45 |
Well I cut out the firewall today and started mocking up my new one with a little higher Trans tunnel, what y'all think?
#46 |
I like your tunnel design. Also just wanted to say thanks for documenting all of your hard work, I will no doubt be following along for tips in the future. Keep up the great work!
#47 |
The trans tunnel looks good.
Kim |
#48 |
Thanks for the likes
#49 |
Very nice pattern for firewall, that the same seat I am using except I pie cut one inch in back to lay the seat more back running the gas tank outside and had the room. If you want to recover that seat later LMC has the seat covers in cloth or vinyl and foam which is real pricey. I am just going to buy high density one inch and glue on top of old seat.
#50 |
All I got done today
