05-28-2012, 12:48 AM | #1 |
What did you do to your truck over the Memorial Day holiday?
Just curious what everyone did to their trucks over the Memorial Day weekend and holiday?
As for me, finished replacing all the ball joints, installed the CPP power steering kit, replaced the idler arm, and replaced the brake hoses on the front drums. Also took the time to buy a new grease gun and made sure everything was properly greased.
1963 Chevrolet C10 Stepside 1972 Pontiac GTO 1998 Dodge Viper GTS 1999 Jeep Cherokee XJ 2018 Chevy Camaro ZL1-1LE It's never too early to beef up my obituary |
05-28-2012, 12:54 AM | #2 |
Re: What did you do to your truck over the Memorial Day holiday?
Painted the interior.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
05-28-2012, 06:42 AM | #3 |
Started cleaning mine up , possibly getting ready to sell mine ..
05-28-2012, 08:02 AM | #4 |
Bad luck set in and I drove my truck that hasn't been on the road in over 2 years all the way to a buddys house (about 40 miles). The reason for the drive was to adjust the valves (making a little noise). Well after pulling the first valve cover 3 rockers were knocked off one valve spring was in pieces, rod was broke, and a valve was bent!!!!!!!!!!! The other side looked ok but all the valves were wore down. So I guess for my Memorial day the top end is being rebuilt.
05-28-2012, 08:15 AM | #5 |
Who Me?
Upper control arm bushing this weekend.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
05-28-2012, 08:39 AM | #6 |
All new brakes front and rear, fixed wiring issues, new fuel tank, put pieces back on I took off over 15 years ago when I started to restore it..... drove it again after being parked for 15 + years..... Sure felt good
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
05-28-2012, 12:42 PM | #7 |
1961 chevy K10 my build is------------61K10 build |
05-28-2012, 01:11 PM | #8 |
I went with Dupli-color light drift sand metallic. I still have to even out the paint some(dry spots). I ran out of paint and no one has it. The can is small and doesn't last long so I drove to 4 stores to find it. I didn't want to spend $100 for a quart and all the stuff that goes with it. I read a tread on this color and I said what the hell I will try it. It looks good I still need to clear, cut and buff.
05-28-2012, 01:18 PM | #9 | |
05-28-2012, 01:35 PM | #10 |
The pic doesn't do any justice. It is real close to the original fawn. i think it has more gold in it and more gloss. The fawn was like a semi-gloss. It looks good now but after I color sand and buff I think it will look better.
05-28-2012, 01:44 PM | #11 |
I helped out my homie work on his 59. Started doing a little bodywork on my 64 but didn't get too far. Too damn hot
Posted via Mobile Device |
05-28-2012, 01:58 PM | #12 |
Added to my tail lights this weekend. I put the chevrons on my fenders to go with the military theme but I didnt measure it when they were off the truck so I tucked them in to far. I really dont want to move them noe because I'm trying to get the truck on the road so I came up with this idea......
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
05-28-2012, 05:13 PM | #13 |
cleaned her up and painted the inside of the chrome window vent shades satin black. Got tired of the military aircraft off-green that was starin me in the face all the time....
05-28-2012, 07:27 PM | #14 |
Guess you would get tired of my truck, everything is olive drab green..
05-28-2012, 07:31 PM | #15 |
ya know, i thought of that right after I posted! No, would not get tired of yours - it's SUPPOSED to be olive drab. I'm diggin the flashlights for taillights. If they work as well as the ones the military issued, you'll be getting tickets all the time...
05-28-2012, 08:04 PM | #16 |
I washed it
05-28-2012, 08:06 PM | #17 |
You didn't say what truck but got this out.
05-28-2012, 09:35 PM | #18 |
Senior Enthusiast
I still love the looks of your truck. Those hubcaps and wheels really make the whole combination come to life.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
05-28-2012, 09:57 PM | #19 |
I took mine to a show saturday afternoon, and today I finished priming my tailgate and blocked it, its looking real close to getting that part of the truck into paint, finally.
Opportunity usually comes disguised....As hard work!!! |
05-28-2012, 10:36 PM | #20 |
i put some lap belts in, and cleaned up my gauge cluster, next is getting the bench seat back in and riveting the license plates to the floor, figure itl look cooler than carpet
05-28-2012, 11:07 PM | #21 |
Just today pulled the distributor apart to clean and replace advance canister and springs.
05-29-2012, 10:32 AM | #22 |
Replaced the ground battery terminal cable. I had some issues with a new battery draining/not charging. This seems to have fixed it!
I also drove around A LOT! Made a short trip over to the Indiana side of the Ohio for a quick picture too! Scott |
05-29-2012, 01:39 PM | #23 |
had a miss develop, so changed out plugs, points, wires, cap, rotor button, condenser, re-checked ignition timing. Mission accomplished runs much better. however i do think my coil is getting weak. i only have about 8 volts coming out of the negative post of the coil. is that to low?
05-29-2012, 02:25 PM | #24 |
Mocked up rockers.. welded.. floating some bondo to clean the door jam back up right now 8)
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726 66 fleet lwb- In process 64 k10 10inch lift 38.5's- In process 92k1500 400hp on 38.5-parts truck now 8( |
05-29-2012, 02:49 PM | #25 |
Cut the holes out of the driver fender, Bent it in, welded in a spot, shaved it back down and coated it until i get a chance to bondo the indention/gaps back smooth
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
