LIL ERV the 50
Well, here she is our 50, these photos are a ways into the build. The frame is almost done here, front end is a 1985 c-10, rear end is a 1985 corvette. If I can find the disk with the photos from the start will post.
Re: LIL ERV the 50
just finished with the mar-k hidden hinge and latch, very nice. the only thing i dont care for are cheap plastic red knobs, will make a set of stainless ones at work.
Re: LIL ERV the 50
cut the cancer out of door bottom, welded in new piece.
Re: LIL ERV the 50
time to cut 9" out of the frame. good bye long box, hello short box!
Re: LIL ERV the 50
made the "z" cut and brought the two pieces together.
Re: LIL ERV the 50
time to get some welding done.
Re: LIL ERV the 50
all welded up and 2 plates on the outside of frame.
#8 | |
Re: LIL ERV the 50
I would ask them to bring them back for the cost Vs. there "Quality" products. Just sayin !!!
Truck Parts Mfg.
![]() Join Date: Jul 2005
Re: LIL ERV the 50
All Mar-K hidden latches have the aluminum knob that you can twist to hold them in the open position. This unique feature is very convenient as you do not need to hold both latches open at the same time to open or close the tailgate. Other suppliers may offer a less expensive latch but if it does not have the aluminum knob that you twist to hold it open, it is not a Mar-K latch. http://www.mar-k.com/product_comparison.aspx#latches.
GET MAR-K Quality! Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks |
Re: LIL ERV the 50
[QUOTE=MAR-Ktech;5457526]All Mar-K hidden latches have the aluminum knob that you can twist to hold them in the open position. This unique feature is very convenient as you do not need to hold both latches open at the same time to open or close the tailgate. Other suppliers may offer a less expensive latch but if it does not have the aluminum knob that you twist to hold it open, it is not a Mar-K latch. http://www.mar-k.com/product_comparison.aspx#latches.[/QUOTE
I bought the hinge and latches from brothers. The hinges are mar-k with their instruction sheets, the latches were in the same box so I thought they were mar-k also, I see that there not, my apologies to mar-k, I have their box and its top notch first quality, next time I will read the ad more carefully. |
Re: LIL ERV the 50
ok, i found my disk of photos of the start, here it is in fargo ND in all its glory.
Re: LIL ERV the 50
At home now not to bad looking.
Re: LIL ERV the 50
Time for the tare down.
Re: LIL ERV the 50
My new front saddle from a 1985 C10.
#15 |
Re: LIL ERV the 50
Fixed the door and pulled off spindles and a-arms, have new 3" drop spindles and having new bushings pressed in a-arms.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#16 |
Re: LIL ERV the 50
You are off to a great start, I'll be shortening my long bed as well, it's nice to see the pictures of what you did, looks great.
#17 |
Re: LIL ERV the 50
thanks.
#18 |
Re: LIL ERV the 50
glad you saved it, good looking truck
![]() looks like mother earth was trying to suck it down and reclaim it for her self ![]() ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#19 |
Re: LIL ERV the 50
Last time it was on the road was 1973! Picked her up in 2004 there abouts.
#20 |
Re: LIL ERV the 50
New borgeson steering shaft and stainless joints.
#21 |
Re: LIL ERV the 50
new bell-tech 3" drop spindles and 3" drop coils.
#22 |
![]() Join Date: Apr 2009
Re: LIL ERV the 50
Looking good man.
![]() did you have to do any grinding on the lower control arm after the 3" spindle? Posted via Mobile Device |
#23 |
Re: LIL ERV the 50
No grinding at all, these are the stock 15" wheels, clearance all the way around.
#24 |
Re: LIL ERV the 50
so the front clip just bolted right up? I'd like to hear more about that set up. First one I seen using this.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#25 | |
Re: LIL ERV the 50
Any saddle from 68 to 87 will fit.
