08-23-2012, 11:54 PM | #1 |
Oil container
My truck has a 350 engine but every time I'm changing the oil is hard to find the filter that goes inside a container. Can this modified into one piece oil filter?
thank you |
08-24-2012, 12:04 AM | #2 |
Re: Oil container
08-24-2012, 02:27 AM | #3 |
Re: Oil container
Usually the 350s had the spin-on disposable type filter. I'm not a V8 expert, but I think they produced the 283, 305, and 327 thru the '68 model year. I think 1967 was the pivot year for the replaceable-element type oil filter. There is an adapter to convert cannister type oil filters to spin-on type.
What year engine are we talking about?
08-24-2012, 10:05 AM | #4 |
Re: Oil container
Thank you Jocko.
I don't know 68OS. My truck is 69 but now I'm thinking the engine is probbaly older. Thank you Guys |
08-25-2012, 06:24 AM | #5 |
1969 Custom 30 wrecker
Re: Oil container
My 69 Custom/30 has the cartridge filter and it's original.
I get filters from Summit and always keep a few extra's around as they are tough to find anymore. They seem to have the best price too. A conversion kit is available to change to spin on filters if that's what you want.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
08-25-2012, 09:10 AM | #6 |
Its a Truck Thing......
Re: Oil container
My 67 283 had the cartridge, did the spin on filter swap. 67 was the last year for 283.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time |
08-25-2012, 10:46 AM | #7 |
Hand Crafted C-10
Re: Oil container
I've always gotten the canister cartridges at NAPA.
My '68 327 had this style. Some parts stores carry the adapter too. |
08-25-2012, 01:52 PM | #8 |
Re: Oil container
Now I'm thinking probably the engine is not 350
08-25-2012, 02:06 PM | #9 |
Re: Oil container
Yes - I'd assume it's not a 350 - probably an earlier year transplant if you have the canister type oil filter. I'm with ETsC10 - I have always gotten my filters from NAPA, they usually have them and they aren't too expensive. If you're in a bind, the "truck vendors" (LMC, etc) usually carry them, but you'll pay a premium price - check locally, especially NAPA, and possibly carquest, firts.
08-25-2012, 02:08 PM | #10 |
Re: Oil container
08-25-2012, 02:31 PM | #11 |
Re: Oil container
Mine to. The old timers always said they used a roll of toilet paper, but I never believed them.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
08-25-2012, 02:34 PM | #12 | |
Re: Oil container
Could it be that the changeover from cansiter to spin-on occurred at the same time as the changeover between large and small journal cranks? i.e. "newer" 327 just before it went out of production? |
08-25-2012, 02:35 PM | #13 |
Re: Oil container
Hey profe56 - if you really want to know what you have, posting the engine block numbers would solve the mystery - the casting number off the driver's side back side of the block is probably the best # to post.
08-26-2012, 06:50 AM | #14 |
Re: Oil container
Still could be a 350. As I mentioned, my 69 which has a 350 has the cartridge filter and it's original. Mine is a custom/30 1 ton so not sure if that has anything to do with it or not.
Post the numbers here from the front stamping pad and one of us can decode it to find out what it really is.
08-26-2012, 01:03 PM | #15 |
Re: Oil container
Yes: I think I should know what I've in my truck. This morning I checked the spark plugs and the 8th is passing oil. I'll start to look for a 350.
08-26-2012, 04:10 PM | #16 |
Re: Oil container
you can buy a GM crate motor very cheap now
08-26-2012, 07:32 PM | #17 |
Re: Oil container
Firstable I'd like to know what's a crate engine,Then how mich it cost and I'd like to see pictures how they look.
In my last visit at the GOOD GUY's Show at del mar I bought a set of aluminum valve covers, and aluminum air filter canister and also I've an edelbrock intake and I think is the time to use it |
08-26-2012, 07:37 PM | #18 |
Re: Oil container
I visit very often the junk yards, specially those where you use your own tools. and I;ve seen big engines than 350s any parts of those engines have a good valu?
Like heads for example |
09-02-2012, 09:44 PM | #19 |
Re: Oil container
I found this # at front of the block under the pasengers side head
V0417U5 |
09-04-2012, 02:04 AM | #20 |
Re: Oil container
V = Pontiac, Mich. Plant
04 = April 17 = 17th The last 2 or 3 digits are the engine codes. Using an old LMC Truck catalog, I get [ '68 292 L6: UH, UT, UP, UO, U3, UM, UQ, UR, UN.] ['69 307: UU, UQ UA, UC, UD, UE, UM, UN, UF, UO, UP.] This is by no means a complete listing. Also LMC sells repop parts, not accuracy. Obviously we're talking about a V8 engine. There are some web sites that specialize in block numbers, maybe someone has a link? We still don't know what year or what actual displacement.
